Home > Wheels & Tyres > TPMS
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
TPMS
Having got a set of wheels with TPMS from Duckworth, very good value for money, and today having the tyres swapped over for winters, when I take my old wheels off and put these on will the car automatically pick up on the new TPMS valves or do I have to do something? letters not necessarily in the right order
Post #416140 1st Dec 2016 11:08am
They certainly always used to.
One thing to look out for is that IIRC they changed the sensors sometime a year or so ago - I recall seeing a posting by Craig along those lines - so hopefully the new ones are compatible with your car.
Post #416158 1st Dec 2016 3:04pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
I messed up when I changed wheels and tires and the sensors didn't go back in their original position .
Iirc , I had to pump all 5 tires to 44psi and drive on the motorway for 20 mins or so to reset everything.
Worth reading the owners manual as I believe it mentions something like this , as sensor position would obviously change if you had a puncture and put the spare on ...
I know nothing about the sensor changes as I'm in California and ours are different to U.K. Ones for some reason ...
Post #435630 22nd Apr 2017 8:22pm
supershuttle
I have the wheels (from Dan) with TPMS sensors, what do I need to add to the car to get them working - is it simple? Very Happy Geoff
Post #435650 23rd Apr 2017 10:12am
Sometimes Whistle
I assume your car already has TPMS ? If not, then it's a lot of work and expense as there are receivers in each wheel arch.
You should just be able to fit the wheels and go for a run - the car should recognise them - there isn't anything else to do to 'program' them.
How old are the wheels ? I think LR changed the system a year or so ago. Early L405 wheels are compatible with L322's but I'm not sure about later ones.
Post #435651 23rd Apr 2017 10:26am
I bought wheels from Dan with TPMS - it is *plug n play* Cool All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #435655 23rd Apr 2017 10:46am
supershuttle
Thanks guys I think my question is answered, the car doesn't have TPMS the new wheels do, but it sounds like a big job to upgrade the car so I'll not be bothering with that, just continue using trusty three quid pressure gauge from China and I'll also get my suspected slow puncture fixed.
Thanks Again Very Happy Geoff
Post #435663 23rd Apr 2017 12:03pm
If you get the chance, I would remove the TPMS valves.
1) They have tendency to corrode - and ultimately snap.
2) they also have some residual 2nd hand value
But mainly #1 - you're better off with bog standard rubber valves Thumbs Up
Post #435683 23rd Apr 2017 4:09pm
Ian c2
Afaik , over here they all had tpms fitted stock .
After the firestone/Ford fiasco they made it law that all new cars must have tpms after a certain future date , with cash incentives given to manufacturers to install systems early .
This was around the time of the l322 introduction so they all have it .
Maybe this is why Usa market cars have different sensors to row cars ?
We also get a stupidly high recommended tire pressure too .
(See my earlier comment about all wheels at +40psi)
I run Mercedes gl450 pressures as I use their 275 tires , and that similar to U.K. Pressures .
Post #435686 23rd Apr 2017 4:36pm
Not mandatory in the UK until sometime around 2015
My L405 doesn't have it
Post #435691 23rd Apr 2017 4:39pm
Ian c2
To be honest , tpms is a pain .
My light is constantly glowing orange .
I've got used to it , but it needs to be off so the check engine light grabs your attention when it comes on !!! Laughing
It's a real basic system that only activates a light on differential , whereas my Carrera from the same era has a screen showing individual tire pressures LIVE .
Post #435692 23rd Apr 2017 4:44pm
Westminster
EDIT: I've just answered my own question I think, the 20" wheels just have standard rubber valves so I'm guessing I don't have it! Problem solved, and money wasted on sensors! Will eBay them when I change the tyres.
Silly me Embarassed
Can anyone tell me how to check if my car has TPMS?
it's a '12 plate L322.
I switched the wheels over to brand new 19s with brand new sensors from land rover but didn't get any error messages or anything after I had changed them.
I have recently changed back to the 20"s to try and diagnose a slight droning noise as the 20" are road tyres.
Both times I have switched the wheels, no errors have shown up.
So either I don't have them and have wasted money on the sensors or it instantly recognised the new sensors and didn't show any errors - I think I know which is more likely though!
Also when I had the tracking done the guy said the tyre pressures were all over the place as I'd just bought it and not checked anything. This hadn't thrown up any errors and the front left was 28psi and rear right 38psi!
How can I check - completely deflate one of my tyres and drive across my lawn?
On the VIN info on Topix there is no mention of TMPS in the build spec.
Thanks for any suggestions!
Post #435948 26th Apr 2017 10:00am
i have the same FF as you Tim and i dont have tpms... ... - .- -.
Post #435965 26th Apr 2017 12:46pm
Westminster
Thanks, yes I'm sure I don't have it now! What an idiot, I thought they all had it haha.
Actually glad that I don't judging by the negative comments.
Post #435993 26th Apr 2017 2:30pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Easy to check.On the same page on your screen where you check the oil level is the option under TPMS to set for "light load"or "heavy load".When I start my car it shows a warning that TPMS is set for light load.
I will not use my RR without TPMS.It has already saved on tyre!!Had a after market set fitted to my D3 and it saved 6 tyres over a 6year period.In our part of the world it is better to have them.
Regards 2012 TDV8 Vogue SE 4.4
Post #440801 6th Jun 2017 3:23pm
