![]() | Home > Technical (L322) > 020 Battery fitting |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 833 ![]() ![]() |
I have bought an 020 to go in..I will let you know how I get on. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1838 ![]() ![]() |
I have also bought an 020, and fitted it. Unfortunately, the battery terminal wouldn't fit. Seems the 020 is too long... |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Hallo together, at 2011 4.4TDV8 313hp fixed this one: http://www.ebay.de/itm/371034812384?_trksi...BIDX%3AIT, only problem is the ECU box, one screw, 30 minutes, and in time of changing I give 12V to the car with externe battery..., best rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
That's not the correct AGM battery |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 773 ![]() ![]() |
Thanks gents - one says yes (even if it isn't an AGM) one says no so I'm still just as confused |
Ok. I have set aside the 12th to have a go. (I am working in Amsterdam next week).
Th battery dimensions seem very critical. 350mm long is around the max, and an 019 fits the bill perfectly
393 mm is the length of the 020.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
had a look at the bits bolted to the battery today.
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 ![]() ![]() ![]() |
Sorry to keep reviving threads......
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
What's the difference between a 019 and an 020?
The 020 is physically longer and is rated at 110AH, the 019 is rated at 95AH.
I tried the 020 in another FFRR, and it still didn't fit
020 is 40mm longer. Looks like ill go for the 019 then. The old one im taking out may be good enough to use in a dual battery setup if it will fit in the boot. 2011 RR Autobiography 4.4 TDV8 |
