![]() | Home > In Car Electronics (L322) > Hardwiring a Dashcam |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8096 ![]() ![]() ![]() |
I've done it twice |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
I have done this on mine by using a piggy-back fuse into an existing fuse that is ignition live. This was behind the glove box. Then I used a 'female' cigarette socket that I had in the garage, so I did not have to chop the end off the wire that plugs into the dash cam.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
Have a look at this |
Dave Member Since: 03 May 2016 Location: Norfolk Posts: 187 ![]() ![]() ![]() |
This is how i did mine
What I did learn after I did mine is that the little AirBag badges on the pillars flip out and there is a single screw behind them to remove the entire pillar cover - at least that's the case on the L405 (I watched them replacing my windscreen)
RRR207 Member Since: 27 May 2016 Location: Basel Posts: 49 ![]() ![]() ![]() |
Great, thanks for such speedy help.
Yes - and you can decide whether to use a permanently live one or one that is switched with the ignition |
The problem is if you used a switch fuse then itncuts out when parked up.
Yep, as alistair says, just 1 torx screw to hold the a pillar trim on. Takes a little lining up with the tangs to get it back together but it's a matter of patience. There is nothing that can't be fixed with a hammer😜😜
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Along with my Blackvue I also purchased a gizmo that shuts down the dashcam should the battery voltage drop below a certain value. Have left my fatty for up to nearly 4 weeks with no starting issues. Previous cars:
Going for the ignition-live option, car doesn't get used for days on end so battery/starting could become an issue with a constant-live situation.
Did the same with mine, you can adjust the voltage parameters so when it drop below it shut down the dash cam its called a Power Magic pro, you can see it in my install post above https://www.blackvue.com/power-magic-pro/ Dave 2012 Vogue Westminster 4.4 |
Hi Dave,
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
It would work for anything plugged in to it. |
