Home > In Car Electronics (L322) > Hardwiring a Dashcam
RRR207
Switzerland 2005 Range Rover Autobiography 4.4 V8 Zambezi Silver
I was lucky enough to be given a DashCam for Christmas that I intent to hardwire for neatness.
I was planning on getting Halfords to do it (£30) but have now discovered that I can get the kit they use for £15 and it just plugs into the fusebox, run the wiring around the windscreen trim and hey-presto!
BUT....
Is there a downside to this method?
If I can find a spare fuse slot in the box, will it be live?
What I'm asking is "Is it as easy as it appears, can I do it or should I pay the extra for somebody with experience?"
Thanks for any advice. Current - RRV Autobiography 4.4V8 2005
Modifications - 20" Westminster Alloys with Grabber AT's. BRC LPG Conversion.
Previous- RRC 3.9V8/91. RRC 4.2V8/94 LSE Softdash. RRC 2.5tdi/94. RRC 2.5tdi/91. RR p38 2.5DHSE/01, Disco2 2.5td5/03, Disco4 2.7tdv6/10 ..... all gone.
Member of the RangeRoverRegister & Wessex4x4Response (Bristol Team)
Post #420066 29th Dec 2016 8:15pm
I've done it twice Thumbs Up
Piggy back fuses are the way to go
http://www.fullfatrr.com/forum/topic12447.html
http://www.fullfatrr.com/forum/topic30917.html
Post #420068 29th Dec 2016 8:20pm
proser
I have done this on mine by using a piggy-back fuse into an existing fuse that is ignition live. This was behind the glove box. Then I used a 'female' cigarette socket that I had in the garage, so I did not have to chop the end off the wire that plugs into the dash cam.
the wire was run along the edge of the windscreen and down the A pillar on the passenger side, then into the side of the dash out of the way. no cable showing at all. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #420069 29th Dec 2016 8:25pm
Have a look at this Thumbs Up
http://www.fullfatrr.com/forum/topic23389....g+dash+cam
I did mine in the same sort of way. Took about 20 mins. I used a different fuse but tbh I think that depends on the MY. Just need to find a spare 12v switched supply. The fuse jumper works well and is a couple of squids and gives you a feed without stripping and splicing into the actual loom. There is nothing that can't be fixed with a hammer😜😜
Post #420070 29th Dec 2016 8:26pm
Dave
This is how i did mine
http://www.fullfatrr.com/forum/topic38044.html Dave
2012 Vogue Westminster 4.4
Post #420073 29th Dec 2016 8:43pm
What I did learn after I did mine is that the little AirBag badges on the pillars flip out and there is a single screw behind them to remove the entire pillar cover - at least that's the case on the L405 (I watched them replacing my windscreen)
That makes it far easier to route the wire than just pushing it from the outside & hoping it stays there Thumbs Up
Post #420075 29th Dec 2016 8:54pm
RRR207
Great, thanks for such speedy help.
I might be being a bit dumb here but I understood I needed a spare fuse slot ..... in actual fact do I just use any slot (I presume it needs to be an appropriate & matching fuse strength?), remove the fuse, plug in the lead & then replace the fuse in the plug? Current - RRV Autobiography 4.4V8 2005
Post #420076 29th Dec 2016 8:56pm
Yes - and you can decide whether to use a permanently live one or one that is switched with the ignition Thumbs Up
The bottom fuse replaces the original & the top fuse is for the new cable - kind of obvious once you know & look at where the cable comes out -
Post #420078 29th Dec 2016 9:02pm
The problem is if you used a switch fuse then itncuts out when parked up.
If you don't use a switched fuse the battery will drain if left for a very long period.
I've found with my blackvue in various cars it's fine for around 4-5days but beyond that the cars start to struggle starting if at all.
A solar trickle charger may help but they are another bag of worms entirely Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #420183 30th Dec 2016 4:53pm
Yep, as alistair says, just 1 torx screw to hold the a pillar trim on. Takes a little lining up with the tangs to get it back together but it's a matter of patience. There is nothing that can't be fixed with a hammer😜😜
Post #420187 30th Dec 2016 5:09pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Along with my Blackvue I also purchased a gizmo that shuts down the dashcam should the battery voltage drop below a certain value. Have left my fatty for up to nearly 4 weeks with no starting issues. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #420330 31st Dec 2016 10:51am
RRR207
Going for the ignition-live option, car doesn't get used for days on end so battery/starting could become an issue with a constant-live situation.
According to the blurb the camera (Nextbase 412GW) will switch on for 30secs under it's own battery power if the movement/noise sensor is activated ...... to be honest I'm not sure if I'm going to leave it in the car 24/7 yet??
Wiring kit is enroute so it'll probably be a job for next weekend, thanks for all the suggestions. Current - RRV Autobiography 4.4V8 2005
Post #420663 1st Jan 2017 10:31pm
Dave
Did the same with mine, you can adjust the voltage parameters so when it drop below it shut down the dash cam
its called a Power Magic pro, you can see it in my install post above
https://www.blackvue.com/power-magic-pro/ Dave
Post #420755 2nd Jan 2017 4:33pm
RRR207
Hi Dave,
Would this work with a Nextbase camera? I'm no electrician but it seems that as you plug the camera into the 'cigarette' socket it would work for any electrical item? Current - RRV Autobiography 4.4V8 2005
Post #420763 2nd Jan 2017 4:49pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
It would work for anything plugged in to it. Thumbs Up 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #420765 2nd Jan 2017 4:50pm
