|  | Home > In Car Electronics (L322) > Hardwiring a Dashcam |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136      | I've done it twice   | ||
|  29th Dec 2016 7:20pm |
| proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452      | I have done this on mine by using a piggy-back fuse into an existing fuse that is ignition live. This was behind the glove box. Then I used a 'female' cigarette socket that I had in the garage, so I did not have to chop the end off the wire that plugs into the dash cam.
|  29th Dec 2016 7:25pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Have a look at this  | ||
|  29th Dec 2016 7:26pm |
| Dave Member Since: 03 May 2016 Location: Norfolk Posts: 187      | This is how i did mine
|  29th Dec 2016 7:43pm |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136      | What I did learn after I did mine is that the little AirBag badges on the pillars flip out and there is a single screw behind them to remove the entire pillar cover - at least that's the case on the L405  (I watched them replacing my windscreen)
|  29th Dec 2016 7:54pm |
| RRR207 Member Since: 27 May 2016 Location: Basel Posts: 49      | Great, thanks for such speedy help.
|  29th Dec 2016 7:56pm |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136      | Yes - and you can decide whether to use a permanently live one or one that is switched with the ignition   | ||
|  29th Dec 2016 8:02pm |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455      | The problem is if you used a switch fuse then itncuts out when parked up.
|  30th Dec 2016 3:53pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Yep, as alistair says, just 1 torx screw to hold the a pillar trim on. Takes a little lining up with the tangs to get it back together but it's a matter of patience. There is nothing that can't be fixed with a hammer😜😜
|  30th Dec 2016 4:09pm |
| appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424      | Along with my Blackvue I also purchased a gizmo that shuts down the dashcam should the battery voltage drop below a certain value. Have left my fatty for up to nearly 4 weeks with no starting issues. Previous cars:
|  31st Dec 2016 9:51am |
| RRR207 Member Since: 27 May 2016 Location: Basel Posts: 49      | Going for the ignition-live option, car doesn't get used for days on end so battery/starting could become an issue with a constant-live situation.
|  1st Jan 2017 9:31pm |
 Did the same with mine, you can adjust the voltage parameters so when it drop below it shut down the dash cam its called a Power Magic pro, you can see it in my install post above https://www.blackvue.com/power-magic-pro/ Dave 2012 Vogue Westminster 4.4 | ||
|  2nd Jan 2017 3:33pm |
| RRR207 Member Since: 27 May 2016 Location: Basel Posts: 49      | Hi Dave,
|  2nd Jan 2017 3:49pm |
| SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792      | It would work for anything plugged in to it.   | ||
|  2nd Jan 2017 3:50pm |
| Posting Rules
