Home > In Car Electronics (L322) > Retrofiting a Bluetooth ULF Module |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 |
What's the sound quality like for those that have done the gen13 upgrade? Mine's awful I've changed to the latest mic etc but sound level and quality for the caller is bad. Anyone know if it's possible to adjust this somehow? "On first name terms with my local Dealer......now."
18th Jan 2015 10:55am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7631 |
My gen 6 is fine, which does not help I know.
18th Jan 2015 11:57am |
Fairly sure I have the mic the correct way round with the arrow on it pointing the way I it said (towards the front of the car). "On first name terms with my local Dealer......now."
18th Jan 2015 12:43pm |
cropps Member Since: 07 Aug 2014 Location: Lancashire Posts: 32 |
Finally sorted the sound problem, had to wait for a nice day & today was it! I was sure there had been some sort of telephone system in the car before as there was an extra mic on the roof. So this morning I started to take the dash apart to try & find out what had been fitted befor, it turns out that there was a Nokia phone kit installed but the cradle had been removed. There is a extra type cover panel on the centre console by the drivers feet, I think this was used to cover the cradle. Behind the panel was the plug for going into a cradle. All of this was hard wired into the Range Rover loom with some wires just cut & not used, speakers I think, any way after a while soldering in very tight places, everything was as it should have been before the kit had been installed. Next was to rebuild dash etc. all went well & success we have sounds out of the front speakers, it doesn't seem to cut the radio out but at least it works.
7th Mar 2015 9:12pm |
Well that's a start then Neil.
7th Mar 2015 9:22pm |
Works fine when you have the mute wire in the right place! |
11th Mar 2015 8:20pm |
yeah.....
11th Mar 2015 8:22pm |
Hi
11th Mar 2015 10:36pm |
Land Rover experience day was awesome. You need to have great faith in the vehicles but taking your feet off the pedals & letting the Range Rover take you down impossibly steep hills takes a bit of coming to terms with! It was well worth the trip. |
15th Mar 2015 9:17pm |
Yes, I did one at Eastnor Castle. It was ace....
15th Mar 2015 9:20pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
Sorry to resurrect the thread...
28th Oct 2015 1:56pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
thank you all for this thread, I have partly installed my bluetooth UFL module today, unit in the boot need to find a way to secure it (it came with a bmw mounting bracket) ordered tonight mic and antenna fingers crossed that will be everything then, I did plug in first without the rewire, luckily just blew a fuse |
14th Oct 2016 9:55pm |
to all that has done the ULF upgrade, does anyone have a Samsung S7 and does it work ?
2nd Jan 2017 8:29pm |
just to update anyone reading this, I think I had a 3rd gen bluetooth module fitted (will confirm the numbers) I then found a 7th gen on ebay (don't think the seller did his homework) collected it today £60 the 7th gen works with my samsung S7 no problems, the voice control also seem to work well to, very happy now
3rd Jan 2017 8:44pm |
