![]() | Home > Technical (L322) > Graunching noise under heavy braking |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
this might help ..
rocksteadyeddie Member Since: 15 Jan 2010 Location: London Posts: 38 ![]() |
Thanks for that. The problem is most obvious under heavy braking - even in a straight line - and without any lock on. Would / could that be the same thing ? |
if its when you brake my first thoughts would be worn pads, have you checked them? ... - .- -.
Not managed to get out in the cold yet. Isn't there a warning light courtesy of our Bavarian friends? |
theres only a sensor on one side so if the other side is worn you wont get a warning light.. ... - .- -.
