Home > Technical (L322) > Graunching noise under heavy braking
rocksteadyeddie
Chaps
Under heavy braking I get a graunching noise which sounds like it is coming from the nearside front wheel. It does not seem to happen under moderate braking. It also occurs occasionally on a steep downhill left hand hairpin near home - again under load I assume.
My immediate thought was that it was brakes but assume that I would have a warning light if the pads were worn, and in any event it is a deeper "graunchier" noise than that.
Any ideas?
Thanks
Post #42172 13th Dec 2010 4:29pm
this might help ..
http://www.fullfatrr.com/forum/topic3869.html ... - .- -.
Post #42177 13th Dec 2010 5:16pm
rocksteadyeddie
Thanks for that. The problem is most obvious under heavy braking - even in a straight line - and without any lock on. Would / could that be the same thing ?
Post #42178 13th Dec 2010 5:24pm
if its when you brake my first thoughts would be worn pads, have you checked them? ... - .- -.
Post #42179 13th Dec 2010 5:29pm
rocksteadyeddie
Not managed to get out in the cold yet. Isn't there a warning light courtesy of our Bavarian friends?
Post #42181 13th Dec 2010 5:32pm
theres only a sensor on one side so if the other side is worn you wont get a warning light.. ... - .- -.
Post #42182 13th Dec 2010 5:34pm
