Home > Technical (L322) > buzzing, resonance,vibration
Page 2 of 6 <123456>
GraemeS
Australia
Mine had a significant vibration resonance triggered by coarse-treaded tyres although probably not your noise as from a slightly different area, being somewhere around the driver's foot-well. The cause was a misplaced spacer clip for the brake pipes emanating from the ABS modulator allowing the pipes to vibrate together, only discovered after replacing the wheel bearing without any improvement.
Post #423363 17th Jan 2017 8:43pm
this is only on idle or increase of revs to around 1000rpm when it gets even worse, again when not moving Graeme...
my son checked all bits underneath when up on a ramp..
Post #423366 17th Jan 2017 8:49pm
GraemeS
Australia
Mine's vibration only occurred whilst moving because that was when the tyres caused panels to vibrate. My thought was that the engine vibration could be causing something else to reverberate so worth checking that the pipes are properly spread by the (IIRC) 2 plastic clips, but perhaps some other pipes might be vibrating. The pipes from the ABS modulator are obscured below the transfer case ecu so can easily be overlooked.
Post #423426 18th Jan 2017 5:08am
we checked the pipes and they were ok Graeme , the consensus now is its somehow related to the engine as the engine block is vibrating/buzzing..
Post #423440 18th Jan 2017 10:09am
Sandyt
Stan what happens above 1000 rpm also is this in neutral or in d but not moving?
Post #423560 18th Jan 2017 8:43pm
Dave 67
England 2004 Range Rover Vogue 4.4 V8 Java Black
Could it be viscous fan related or something in the torque converter? 2004 4.4V8 Vogue
BMW 330CD
BMW523i
Escort Mexico MK1
1974 airportable series 3
Post #423565 18th Jan 2017 8:57pm
Can you hear the vibration under the car? There is nothing that can't be fixed with a hammer😜😜
Post #423566 18th Jan 2017 8:58pm
Idea.....
The drivers side of the trans tunnel is where the module for the steps is "wedged" if the fitters didn't fit the foam round it it could be rattling under the trim. There is nothing that can't be fixed with a hammer😜😜
Post #423568 18th Jan 2017 9:00pm
@sandy, over 1000rpm it disappears whether in neutral or drive...
@dave , not sure if it could be those, it only appeared after the turbo drain mod and the steps being fitted and i'm sure the fan or TC was touched..
@mark, my son checked underneath and it wasnt apparent there , but i will double check again.....
strangely when i fitted some replacement xenon bulbs the other day , i touched the top of the engine and the vibration was prominent , it felt like the engine was running a bit to fast. like it was on choke, but the rev counter says around 700rpm..
Post #423582 18th Jan 2017 9:36pm
does anyone know if the idle can be adjusted ?
Post #423590 18th Jan 2017 10:02pm
proser
possible from altering the engine map, but no aware of anything that could be done from otherwise. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #423599 18th Jan 2017 10:24pm
no screw to turn then Mark.... Laughing
Post #423600 18th Jan 2017 10:28pm
proser
Rolling with laughter Rolling with laughter Regards
Mark
2012 Westminster
Post #423607 18th Jan 2017 10:43pm
Rob99
Ah, those were the days.........adjusting the mixture and idle screws Very Happy
. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #423628 18th Jan 2017 11:59pm
miggit
Whistle Assuming that you haven't been to the Ann Summers Shop, Shocked , You're complaining of a buzzing or is it a vibration?
Buzzing... are there any return springs on your part time steps?
Vibration.. if the engine is feeling lumpy, could it be an injector fault? Only I was convinced that my TCC was going again last year, right up until the injectors went and effectively gave me a ffrr with a freelander TD4 engine below 2000 RPM Shocked When it all gave out totally it was obvious that it was an injector... but for the 6 months leading up to the failure I thought it was my TCC.. one thing I did find was the higher the engine revs the more 'normal' it felt Rolling Eyes
Failing that can you turn the Radio up Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #423632 19th Jan 2017 1:03am
