![]() | Home > Technical (L322) > buzzing, resonance,vibration |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
this is only on idle or increase of revs to around 1000rpm when it gets even worse, again when not moving Graeme...
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2745 ![]() ![]() |
Mine's vibration only occurred whilst moving because that was when the tyres caused panels to vibrate. My thought was that the engine vibration could be causing something else to reverberate so worth checking that the pipes are properly spread by the (IIRC) 2 plastic clips, but perhaps some other pipes might be vibrating. The pipes from the ABS modulator are obscured below the transfer case ecu so can easily be overlooked. |
we checked the pipes and they were ok Graeme , the consensus now is its somehow related to the engine as the engine block is vibrating/buzzing.. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Stan what happens above 1000 rpm also is this in neutral or in d but not moving? |
Dave 67 Member Since: 11 Dec 2016 Location: Oxfordshire Posts: 34 ![]() ![]() ![]() |
Could it be viscous fan related or something in the torque converter? 2004 4.4V8 Vogue
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Can you hear the vibration under the car? There is nothing that can't be fixed with a hammer😜😜
Idea.....
@sandy, over 1000rpm it disappears whether in neutral or drive...
does anyone know if the idle can be adjusted ? |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
possible from altering the engine map, but no aware of anything that could be done from otherwise. Regards
no screw to turn then Mark.... |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1481 ![]() ![]() |
Ah, those were the days.........adjusting the mixture and idle screws ![]() . 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
