![]() | Home > Technical (L322) > folding door mirrors |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
the Westie has an issue with the drivers dorr mirror.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
makes me think the battery is lacking power.....does this kinda happen when you first open up or when the FF has been run and warmed up a bit as well.. |
battery was fully charged just 2 days ago but might check to see what the C-Tek charger says in the morning. Another story that I am waiting for the selling dealer to get back to me on.
so the door switch is sending power to the mirror directly without problems , whereas the remote sends a signal to an ecu and that then sends the power to close/open which isnt working correctly...ecu? |
thanks. an email to selling dealer to explain issue and see what they are going to do. Regards
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Any update on this? I have exactly the same symptoms Bish.
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
Have you popped the cover off to have a look at the small metal arm on the micro switch? Could be thats it not fitted properly and the mirror isn't sure what position it is in.
Well it seems a good soak in WD40 and a few cycles of the mirrors and normal service seems to have been restored...... for now...... Bish.
