Home > Technical (L322) > folding door mirrors
proser
the Westie has an issue with the drivers dorr mirror.
When locking the RR the mirror closes but seems to be slower than the passenger side and does not close fully. It has a bit of slack in it. If I push it fully closed then when I unlock the FF the mirror will not open back up, but leave alone and it will Neutral
When operated from the door switch it closes fully and opens again with no problems as all.
Anybody had this ?? Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #423368 17th Jan 2017 8:55pm
makes me think the battery is lacking power.....does this kinda happen when you first open up or when the FF has been run and warmed up a bit as well..
Post #423370 17th Jan 2017 9:04pm
proser
battery was fully charged just 2 days ago but might check to see what the C-Tek charger says in the morning. Another story that I am waiting for the selling dealer to get back to me on.
it happens every time I lock up. door switch is fine with just the ignition on (engine off) Regards
Mark
2012 Westminster
Post #423371 17th Jan 2017 9:07pm
so the door switch is sending power to the mirror directly without problems , whereas the remote sends a signal to an ecu and that then sends the power to close/open which isnt working correctly...ecu?
Post #423376 17th Jan 2017 9:19pm
proser
thanks. an email to selling dealer to explain issue and see what they are going to do. Regards
Mark
2012 Westminster
Post #423379 17th Jan 2017 9:22pm
bishbosh10
Any update on this? I have exactly the same symptoms Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #425912 1st Feb 2017 8:53pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Have you popped the cover off to have a look at the small metal arm on the micro switch? Could be thats it not fitted properly and the mirror isn't sure what position it is in.
Here is a great tutorial by Joe90 which shows you what to do:
http://www.fullfatrr.com/gallery/thumbnails.php?album=341
Post #425925 1st Feb 2017 11:02pm
bishbosh10
Well it seems a good soak in WD40 and a few cycles of the mirrors and normal service seems to have been restored...... for now...... Bish.
2005 110 TD5 CSW
Post #426808 7th Feb 2017 11:24pm
