![]() | Home > Technical (L322) > buzzing, resonance,vibration |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8747 ![]() ![]() ![]() |
Problems with NVH are usually down to mass of the object and resonance through it, you have changed the mass by adding the steps, standing on them will stop them vibrating but it is usually the weakest part that will vibrate so it maybe worth following the earlier advice to remove them and see if that helps, you seem to have covered everything else...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
@paul, i thought injectors as well hence the shell nitro and diesel additive ...when moving the westie runs perfect , i even took it up to 130mph whilst on a break abroad...
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
In my experience the only injector cleaner that worked was Ultrasonic..... on a test rig, at the Bosch service centre |
around 72k paul..
Possibly... live data on the injectors gives an indication, they should all be roughly the same.. And while 72K is a low milage, you are getting into dirty injector regions |
thanks paul...it beggers belief that i've more sense from the forum than the dealer.... |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
We are here to help each other, the dealer is just there to make money and they are not doing that with you currently. ![]() Mark 2012 Westminster GONE - 2007 Java Black FF Vogue, with Ivory interior |
A dealer is only as good as his Testbook |
re ''Bosch Service Centres'' theres a couple in swindon, what more can they do that the dealer can Paul..
For a kick off they have test rigs for the injectors... and cleaners too! And bearing in mind that Bosch supplied the injectors to start with, LR will be using Bosch software to operate them! Plus they will have flow and pressure test equipment that the stealers wont have access to, or any idea how to use |
Here's a sample of the RPM from mine at idle, if you need to compare
valid point paul.... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3864 ![]() ![]() ![]() |
I hope you get this sorted soon Stan, I am getting paranoid.... listening for the slightest rattle, vibration, noise etc every time I go out, but thankfully everything seems fine on mine following the turbo drain mod work.
cheers mike, your dealer obviously did the job properly... |
