Home > Technical (L322) > DAB Radio + Sub Woofer
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
DAB : First time I have had this in a car and I have never made a journey ( usually 30 mins ) without the signal being lost and I have to pick another station. Dealers say it is normal as DAB is fairly new and the transmitters are minimal..is this normal ?
Sub Woofer : Been in garage 4 times for this so far, it doesn't work, adjusting the setting on various music types doesn't make any difference, it has had a new speaker and new DAB module, does everyone elses notice a difference when they whack it up to full...just checking as it is going in again in a week for them to try again...any advice / experience greatly received : Cheers ..Jeff
Post #425254 28th Jan 2017 7:09pm
if you pick a national station on the dab then you can listen to it across the dab network...pick a local one then you'll loose it when you go out of range...
Post #425272 28th Jan 2017 8:19pm
muppet
Thanks, I have chosen national ones and it does the same, not as frequent but you get that crackle, then it goes off...if you wait it comes back but think I would rather use normal FM, appreciate the reply...
Post #425275 28th Jan 2017 8:30pm
dab is the same as digital tvs in regards to reception, go in between buildings or drive into a dip and the signal goes...
Post #425278 28th Jan 2017 8:39pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Regarding the sub woofer, I was convinced mine was on the blink until I moved the fade more rearwards. Some songs the sub is noticeable but others the front speakers seem to take over......depends on how the track was recorded?
I've not tried CDs yet but the sub worked well with R2 DAB; I mostly play playlists from an old iPod Classic which I have set for added base.
Post #425281 28th Jan 2017 8:47pm
miggit
Whistle I discovered recently that my Sub was never connected...ever Shocked but you'd never have known... It sounds to me that the sub is running on a very low frequency, that would cause it to not notice as much as you'd expect... try playing some Drum n Bass and see how it goes Shocked If that don't make it work noticeably then it's fubar'd Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #425344 29th Jan 2017 1:44am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I thought my sub woofer wasn't working and also got it checked. Turns out it works differently to older models. It doesn't seem to work for low volumes. Needs a bit of welly to get it going. For'easy listening types like me this is a pain. Always sound tinny.
I gave the sound a bit of a blast at increasingly high volumes and that seems to have helped 'break in' the sub.
I agree moving the fader back helps. Also turn up the bass a little in relation to the treble. The clarity of sound is excellent but it just doesn't have the bass at low volume.
In summary the sub is much less noticeable than on older models. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #425348 29th Jan 2017 7:59am
Giantlandyman
^ "Needs a bit of welly to get it going."
Bow down
Zip di de do da, zip di de day........
That's just the excuse I needed Thumbs Up
I thank you. Twisted Evil
Post #425357 29th Jan 2017 10:17am
muppet
few things to try there, many thanks for your responses, i will go and annoy the neighbours now....
Cheers : Jeff
Post #425410 29th Jan 2017 4:35pm
