![]() | Home > Technical (L322) > DAB Radio + Sub Woofer |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
if you pick a national station on the dab then you can listen to it across the dab network...pick a local one then you'll loose it when you go out of range... |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 91 ![]() ![]() ![]() |
Thanks, I have chosen national ones and it does the same, not as frequent but you get that crackle, then it goes off...if you wait it comes back but think I would rather use normal FM, appreciate the reply... |
dab is the same as digital tvs in regards to reception, go in between buildings or drive into a dip and the signal goes... |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
Regarding the sub woofer, I was convinced mine was on the blink until I moved the fade more rearwards. Some songs the sub is noticeable but others the front speakers seem to take over......depends on how the track was recorded?
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I thought my sub woofer wasn't working and also got it checked. Turns out it works differently to older models. It doesn't seem to work for low volumes. Needs a bit of welly to get it going. For'easy listening types like me this is a pain. Always sound tinny.
^ "Needs a bit of welly to get it going."
few things to try there, many thanks for your responses, i will go and annoy the neighbours now....
