Home > Technical (L322) > Global opening and closing
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
Afternoon,
MY2011
My car opens all windows when holding down the unlock button
however the nearside windows dont close when holding down the lock button ?? - windows all work fine
any ideas
Ta muchly 2011 Range Rover Vogue SE
Post #426443 5th Feb 2017 5:49pm
those windows might not have one shut/opening programmed....open each window and hold down the switch, hopefully that will activate this.
Post #426457 5th Feb 2017 6:37pm
Busa1400
thankyou will try now 2011 Range Rover Vogue SE
Post #426459 5th Feb 2017 6:43pm
Busa1400
Managed to get the drivers to do it not the passenger side 2011 Range Rover Vogue SE
Post #426557 6th Feb 2017 2:02pm
Mikeinatruck
United Kingdom 2018 Range Rover Autobiography SDV6 Santorini Black
You need to reset them I had this.. sit in it with all the windows open, close each one manually, keep your finger on the switch, when it is closed release the switch and straight away pull the switch up again for about 3 seconds, do each window in turn , this should reset them. Does your sun roof work with global close? I cant get mine to reset, not sure if it is part of the system or not but book says it is...
Post #426625 6th Feb 2017 9:32pm
