![]() | Home > Technical (L322) > Global opening and closing |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
those windows might not have one shut/opening programmed....open each window and hold down the switch, hopefully that will activate this. |
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 ![]() ![]() ![]() |
thankyou will try now 2011 Range Rover Vogue SE |
Managed to get the drivers to do it not the passenger side 2011 Range Rover Vogue SE |
Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 50 ![]() ![]() ![]() |
You need to reset them I had this.. sit in it with all the windows open, close each one manually, keep your finger on the switch, when it is closed release the switch and straight away pull the switch up again for about 3 seconds, do each window in turn , this should reset them. Does your sun roof work with global close? I cant get mine to reset, not sure if it is part of the system or not but book says it is... |
