Home > Maintenance & Mods (L322) > Replacing rotten boot floor on a l322
Jonny789
United Kingdom 2003 Range Rover Vogue SE Td6 Fuji White
Hey all, we have a l332 in where the boot floor is very rusty on the underside and has a couple of corrosion holes the size of a child's fist. We have ordered a genuine Land Rover repair panel section which looks like this
Has anybody had to replace the boot floor before or is this unheard of? Any tips would be very helpful.
Thanks
John
Post #430282 6th Mar 2017 9:12pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
at that sort of money unless you need the wheel well I would be tempted to just weld in a flat panel for the cost's, never heard of a L322 rusting badly in the boot maybe where the car's been kept ?
Post #430292 6th Mar 2017 9:43pm
Jonny789
Thanks for the quick reply, the car itself is in pretty good nick, it's just from the rear wheels back which makes us think it's been used for launching boats in the sea possibly? Once the new floor is welded in we will be shot blasted the rear underside of the car, we are a little concerned as the rear crossmember the air bags sit on looks quite scabby, are the l322's prone to rot in these areas ?
Post #430293 6th Mar 2017 9:50pm
Lukie
not heard of a l322 being very rusty in boot area at all, they do suffer with wheel arch's
Post #430304 6th Mar 2017 10:36pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Have a look under the sill covers towards the rear of the car, there may be some rust under there....... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #430340 7th Mar 2017 10:23am
CS
I recall another thread which showed bad rust around the bottom corner of the rear wheel arch, coming from inside the panel. There are also threads on water collecting in the spare wheel well from leaks above. Only Range Rovers since 1988
Post #430357 7th Mar 2017 12:49pm
mjdronfield
Yea...water can gather in there if there is a leak from the rear tailgate seal, or sometimes from the bolts in there that hold the back bumper on.
Not had first hand experience but have read a few threads..... though if it's all over the rear on the outside as well, might not be that.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #430377 7th Mar 2017 3:09pm
Jonny789
Here's the photos of the corrosion, after a poke about we are glad we bought the expensive Land Rover repair panel now
It's well and truest rotten
The new panel ready
Post #430378 7th Mar 2017 3:25pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Hey Jonny789
What year is the car ?
We have had quite a few of these L322 from 2008 to 2012 - never seen rust before.
I can only presume the previous owner had a leak in the back and water got into the boot -
The 2 L322 we have have completely been waxed oiled all over - the rear was done twice since brand new - 5 years later the wax oil is still there - protecting.
Good luck with the fix.
Post #430392 7th Mar 2017 7:59pm
Jonny789
The car is a 2003 car but has had the 2012 lift done, looking round it inside and out you would think it is only 5 years old.
The underside and air bag crossmember is pretty scabby but seems solid.
However we took the plastic sill covers off late this afternoon and found the rear sills around the jacking points were very badly corroded and I could put my fingers straight through leaving a hole around 11 inches long. We are not mot sure if it's savable... both rear sills are corroded and holed from the rear jacking point to under the front of the rear doors
Post #430398 7th Mar 2017 8:28pm
Mine's also pretty horrible for rust. Just eeking out it's remaining life. It is 15 years old later this year so it's not something to be upset about.
Post #430418 7th Mar 2017 11:16pm
UK Marine
Sorry about the sills, I had a feeling.
I read somewhere (I hope it's not true) that sills are not available as repair panels... Big Cry ______________________________
Simon
Post #430434 8th Mar 2017 9:44am
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
My boots gone in the same place, so you aren't the only one.
Mines a 2002, and judging by the underside it's been used to launch boats or something similar.
I'm not too worried, if it gets any worse ill just get a plate welded over it!
Post #430458 8th Mar 2017 2:23pm
Jonny789
Boot floor mainly cut out, she looks scabby
As suspected, traces of sand, it's definitely been a boat launcher
Post #430460 8th Mar 2017 3:25pm
Jonny789
New panel plug welded in place and seam sealed
Photo showing the plug welds
Post #430461 8th Mar 2017 3:27pm
