![]() | Home > Maintenance & Mods (L322) > Replacing rotten boot floor on a l322 |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
at that sort of money unless you need the wheel well I would be tempted to just weld in a flat panel for the cost's, never heard of a L322 rusting badly in the boot maybe where the car's been kept ? |
Jonny789 Member Since: 27 Feb 2017 Location: somewhere Posts: 8 ![]() ![]() ![]() |
Thanks for the quick reply, the car itself is in pretty good nick, it's just from the rear wheels back which makes us think it's been used for launching boats in the sea possibly? Once the new floor is welded in we will be shot blasted the rear underside of the car, we are a little concerned as the rear crossmember the air bags sit on looks quite scabby, are the l322's prone to rot in these areas ? |
not heard of a l322 being very rusty in boot area at all, they do suffer with wheel arch's |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
Have a look under the sill covers towards the rear of the car, there may be some rust under there....... ______________________________
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1417 ![]() ![]() ![]() |
I recall another thread which showed bad rust around the bottom corner of the rear wheel arch, coming from inside the panel. There are also threads on water collecting in the spare wheel well from leaks above. Only Range Rovers since 1988 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Yea...water can gather in there if there is a leak from the rear tailgate seal, or sometimes from the bolts in there that hold the back bumper on.
Here's the photos of the corrosion, after a poke about we are glad we bought the expensive Land Rover repair panel now
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 354 ![]() ![]() ![]() |
Hey Jonny789
The car is a 2003 car but has had the 2012 lift done, looking round it inside and out you would think it is only 5 years old.
Mine's also pretty horrible for rust. Just eeking out it's remaining life. It is 15 years old later this year so it's not something to be upset about. |
Sorry about the sills, I had a feeling.
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
My boots gone in the same place, so you aren't the only one.
