Home > General > What Did You Do In Your Full Fat Today
Page 244 of 385 <123 ... 243244245 ... 383384385>
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
Changes the gearbox oil and filter, at 122,500 miles it's squeaky bum time with a TD6 box..... Shocked
Despite the fill plug feeling like it hadn't been touched in 11 years, which resulted in a larger nut having to be welded to the filler plug to remove it.... Rolling Eyes the fluid actually looked surprisingly good, not exactly red like new, but not black either, a sort of reddish brown which I was happy with, and the sump magnet having a light coat of a dark grey slurry or paste, nothing too large or shiny.
I bought a 20 liter drum of fluid so I think it's run it for a few thousand miles and give it a change again.
No great difference in the way the box performs, perhaps slightly smoother, could be the placebo effect bit then again I didn't really have any complaints to start with.
Post #434031 6th Apr 2017 3:50pm
Weegie
You don't mention it but did you change the filter as well? I would also only use a Filtran filter. John
GAP iiD BT-Sold
Post #434033 6th Apr 2017 4:20pm
hamlet
Well spotted Weggie, yep, changed the filter too, couldn't get a Filtran, I know it the recommended one, I can't remember for the life of me the name of the filter I used, I got a filter kit including the sump gasket and new bolts from my local motorfactor, he's usually pretty good and I did warn him I didn't want to put rubbish into it so hopefully it's ok.
Post #434038 6th Apr 2017 5:02pm
Gumball3000
United Kingdom 2011 Range Rover Vogue SE TDV8 Zermatt Silver
Towed my caravan for the first time with the FFRR , didnt hardly know it was there . Its a 1600 kgs caravan too, easy !!
Post #434297 8th Apr 2017 9:50pm
mpirie
Replaced both front and rear brake pads. Thumbs Up
Post #434298 8th Apr 2017 10:08pm
stu
Nothing cos my wife had it!!... Crying or Very sad Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #434493 10th Apr 2017 7:45pm
p38arover
Australia
Installed a dual battery system.
It's a first pass and could have been better laid out. I do intend to make a Mk2 version.
Do you want to see it? I'll find a dual battery thread and add the story there. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #434701 12th Apr 2017 12:25pm
mikeyyn
Bought a IID tool on Dan's group buy, can't wait to play. Thumbs Up
Post #434712 12th Apr 2017 2:08pm
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Went for haircut Thumbs Up
Post #434722 12th Apr 2017 3:47pm
Gumball3000
Looked at the big bird s**t on the back of it just after i washed it.
Post #434725 12th Apr 2017 4:10pm
stu
Had a lovely set of General Grabber A/T3's fitted and changed my twin electrics to single 13 pin set up.
Can't wait to tug my tin tent in a fortnight. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #434832 13th Apr 2017 7:38pm
jonnyboy54321
Had a mysterious random slow puncture looked at, Nothing found so re-sealed, new valve and balanced.
Although she had a service 2 weeks ago she had a quick levels check, screenwash and tyre pressures ready for a northerly visit tomorrow - looking forward to that. Well, apart from the 7 hrs it will invariably take... 2007 Vogue TDV8 with 255/55/20's fitted
Post #434845 13th Apr 2017 9:55pm
GGDR
Finally did some motorway travel in my 4.4TDV8. Not too far, London to Swindon and back, then again two days later to collect our daughter from camp. Only around 320 miles all in.
Such a comfortable car.
The best part? watching the Av MPG creep up on the M4. Went over 30. Then 31. It was entertaining in itself, I was thinking, no way it'll got over 33. In then end got 35mpg
Also did a DPF clear out. Dropped it down to 6th (can't believe I can say that) and held it just over 2000rpm on the cruise.
Orange (DPF) light went out in 15 mins.
Adaptive cruise works a treat too. Cheers, Greg
Post #434868 14th Apr 2017 7:39am
Freddie The Fish
United Kingdom 2011 Range Rover SE 4.4 V8 Fuji White
Stopped the damn glovebox rattling, small bit of cloth tape round the latch.... silence at last
Post #434888 14th Apr 2017 12:57pm
pip1977
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Busy day on the fatty today, changed the oil and filter
fuel filter, front and rear discs and pad and sensor wires.
Both lower arms and drop links.
New condenser to go in tomorrow.
Drives great now and doesn't knock. 2004 td6 Zambezi silver
2006 fiat scudo van
1971 1300 vw beetle
Post #434992 15th Apr 2017 8:51pm
