Home > General > What Did You Do In Your Full Fat Today
Page 245 of 383 <123 ... 244245246 ... 381382383>
Heathy
United Kingdom 2011 Range Rover Vogue SE TDV8 Fuji White
Gave her a blast to clear the DPF Cool Vogue SE 2011 MY 4.4TDV8 in Fuji White
RSE, Surround Cameras and Deployable Side Steps
Post #435037 16th Apr 2017 11:05am
jambo27
Said goodbye to my S/C Sad Sad Sad what to get next Confused 2008 TDV8
Post #435038 16th Apr 2017 11:14am
mpirie
^^^ Another one? Thumbs Up
Post #435049 16th Apr 2017 12:02pm
Cooper1275
Ireland 2006 Range Rover Vogue SE Td6 Buckingham Blue
Well yesterday....
had a squeak coming from my from brakes for a while so...
changed pads on all four corners, cleaned, greased and lubed.
discovered uneven wear on the pads squeaking but now its all good.
no more squeak Thumbs Up
Post #435053 16th Apr 2017 12:23pm
RRR207
Switzerland 2005 Range Rover Autobiography 4.4 V8 Zambezi Silver
Spent a shed load more money on it Big Cry Big Cry Big Cry Big Cry Big Cry
The MOT was not a pleasant experience as the most of the brake pipes are shot Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry
In the first year of ownership I've nearly spent as much on maintenance as I spent to purchase the damn thing in the first place and it wasn't cheap as I held out and paid slightly over the odds for a good one ...... at least that's what I thought!
Having said that I still love & wouldn't swap it ....... how stupid is that! Shocked Shocked Shocked Current - RRV Autobiography 4.4V8 2005
Modifications - 20" Westminster Alloys with Grabber AT's. BRC LPG Conversion.
Previous- RRC 3.9V8/91. RRC 4.2V8/94 LSE Softdash. RRC 2.5tdi/94. RRC 2.5tdi/91. RR p38 2.5DHSE/01, Disco2 2.5td5/03, Disco4 2.7tdv6/10 ..... all gone.
Member of the RangeRoverRegister & Wessex4x4Response (Bristol Team)
Post #435631 22nd Apr 2017 8:24pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Painted the rear backbox. Looked so tatty and really stood out when the car was clean.
Easy to fix though. 30 mins and £10 worth of Hammerite metal paint with a satin finish.
Half & half. Really shows you the difference in colour. Its fresh on here so looks glossy but dries satin..
Finsihed painting. Took one 400ml can.
From afar
Fully dried:
 Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #435698 23rd Apr 2017 5:18pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
looks good, need to do mine now Smile
Edit doing mine now Razz. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #435714 23rd Apr 2017 7:20pm
rar110
That's a flash looking shed for the L322. I need one for my backyard. ______________________________
Post #435723 23rd Apr 2017 8:07pm
JPHC
It's where she lives Thumbs Up Jordan
'56 SC 4.2 ‘16-‘18
Post #435734 23rd Apr 2017 9:03pm
b348xyx
Copied the above, and give mine a quick paint with high temp spray paint Matt black.
Looks so much better then before.. was quite bad..
Post #435794 24th Apr 2017 4:50pm
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
Had to take the fuel pump back out today after replacing it a fortnight ago as the fuel gauge was not reading full.
The float had dropped off the pump body.
Post #435985 26th Apr 2017 1:57pm
GPMG
England 2004 Range Rover Vogue Td6 Epsom Green
Todays Jobs
Well, changed all the dif oils plus transfer box. Replaced secondary fuel pump TD6. Reconned the sir pump with new piston ring and air drier fill. New bonnet and tail gate struts.
Power steering fluid next!
Cheers
Post #436466 30th Apr 2017 2:06pm
Made and fitted a removable load bearing rear shelf to use in place of the rear load cover.
Post #436472 30th Apr 2017 2:56pm
RiBs
Smile Smile Smile Smile Drove it home after purchasing it !!!!! Laughing Laughing Laughing
Post #436560 1st May 2017 12:51am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Passed the yearly DOE , ( commercial MOT in ireland) had oil change yesterday and mechanic commented how the oil is like new. I change every 10k kilometres and use Liqi moly oil. Left testing station with aircon on , cooled seat on and sunglasses on , also a big smile Very Happy 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #436907 3rd May 2017 4:45pm
