Home > Technical (L322) > iPod again
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Thanks SteveMFr,
A MKIV did indeed come along. £270..! subject to snow/backlog in depots, all items should be winging their way to me now..! I gather the DVD is a straight swap out. the Intravee I guess is swap leads around and replug. the only hard bit would be routing the ipod cable into the center cubby box..? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #43779 28th Dec 2010 1:34pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Don't know if it helps re: Intravee install:
http://www.fullfatrr.com/forum/topic1556.html
Post #43804 28th Dec 2010 4:38pm
comports
Thanks all. The Intravee II and Apline somethingorother arrived today in the post.. Very Happy
Guess what I'll be doing in the next couple of days. I just hope it doesn't take too long or is too involved. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #44927 6th Jan 2011 8:22pm
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
comports, I did this in the summer. My car also needed the plug to be re wired that originally connected to the CD player which I bought from a BMw dealer. All straight forward once I got this. My only watch out would be the removal of the air vent needed to remove the glove box. DONT follow some internet instuctions that say JUST PULL. There are some plastic spring clips on the inside and on each side of the airvent that you need to prise inwards with a small screwdriver to release the air vent. Dead simple once you know but as I say DONT just pull the air vent as I did. It will break and is £90 to replace.
Smileys for my daughter who is watching me type this..... Rolling with laughter Big Cry Laughing Embarassed
Post #44929 6th Jan 2011 8:36pm
comports
- You mean I may have to rewire a certain plug..? Where does one find the correct plug..? Got any part numbers or descriptions please... Sad Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #44938 6th Jan 2011 9:02pm
CMJ
Maybe it depends on what you find when you reach the back of the CD changer. Unfortunately there is no way to tell before you have stripped the car to gain access. Apparently more plugs are the correct ones vs are not but if you are anything like me sods law will apply. Again there is plenty written up on this search Range rover intervee install etc and you will get some very good step by step instuctions. Remember though, DONT pull the air vent !
PS - I dont have the part number for the plug but if you find you need one let me know and I will try and do a search to assist. BMW had them in stock for about 25p !
PPS - Have just reviewed the link in the above post and these contain the instructions if like me you had a 10 pin plug and what you neeed to do to rewire a new plug. I can confirm these are what I followed and all worked very well.
Post #45007 7th Jan 2011 9:04am
comports
OK - Thanks CMJ - I'll let you know when I get it stripped out.. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #45024 7th Jan 2011 10:54am
comports
HI CMJ - Sods law applied to me also. I have it all stripped out and have the 10 pin plug..! Big Cry
Interestingly - it has a second plug attached in line just before the end. I unplugged this and it just happens to be the correct fit for the iBus connection
Any chance you could dig out some info for me to purchase the correct plug so i can re wire it.?
Thanks
Ash Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #45233 9th Jan 2011 4:00pm
CMJ
Hi
I think it was item no 7
http://www.realoem.com/bmw/showparts.do?mo...&fg=15
The drawing is not very good.
If the part number has been superceeded the BMW guys will know the replacement
You dont need to buy the pins and the instrcutions in the previous post above explain how to remove from the old plug to the new. Take your time and ensure you get them in the right order. Simple as that.
Added later : Have found some more instructions to assist. Let me know how you get on and if I can offer any more assistance
http://www.roverupgrades.com/cd2intravee.html
Post #45296 9th Jan 2011 10:07pm
comports
Thanks CMJ - I wonder - can you confirm for me that this is the correct part number.
61136913635 and is it something I can just orde rover the phone with a BMW dealer.
Thanks
Ash Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #45407 10th Jan 2011 4:01pm
