Home > Technical (L322) > 2009 interior upgrade for my 2003 ffrr
Page 1 of 3 123>
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi all
This is my first post on here, but been browsing this great site for quite a long time. My question is quite a complicated one I have the opportunity to acquire a complete 2009 ffrr interior in my favorite colour - ivory/jet which i want to fit into my 2003 ffrr - the reasons for the upgrade are quite simple i much prefer the later 07+ interior vs the 02-05 interior and the entertainment system is enhanced over the MK3/MK4 system in the 02-04 models.
My question is does anyone know if this is possible, my plan is to purchased the complete interior, front & rear seat, complete dash and centre console, door cards, A-D post trims, headlining, complete entertainment system - speakers, amps, front screen etc.. My plan was to also purchase all the wiring looms and ECU's from the 2009 vehicle and 'transplant' them into my car along side the current wiring looms for my current systems. Im hoping that this should not be too difficult as the majority of the items i want to upgrade/add are 'cosmetic additions' and after studding the electronics in the 2009 vehicle I know the majority of the cars configuration is held in the instrument cluster, and using my MSV-2 Extreme my plan is to do all the ECU programming myself.
With all this my only real concerns are with the actual instrument cluster because as far as i am aware the newer 2009 cluster cannot be used with the earlier BMW 4.4 engine management system, so my plan for this was to use the gateway ECU (to hold the CCF) that was in the 2005 (touch screen model) to act as the 'gateway' between the older BMW electrics and the current CAN bus network that the newer systems operate over. If anybody knows any reason why this would not work could you please let me know. My only other real concern is the safety restraint systems e.g. airbags and seat belt pre-tensioners as in the 07+ interior the front passenger airbag moved to be built into the actual dash rather than in the fascia of the dash, does anyone know if it is possible to connect a newer shape airbag to the 2003 airbag system. Same with the seat belt pre-tensioners, these are located on the seat belt receiver (what you plug the seat belt into) and this is then connected to the vehicles wiring loom. I know that the 2009 seats still run on the older ibus system so i am hoping that the seats will just plug straight into the 2003 wiring connectors that my current seats connect to. The entertainment system is a relatively closed system running on its own MOST fibre optic network and also BBS is currently working on the same project (trying to integrate the touch screen system into the 03 model) so if anyone can get it to work correctly it is Colin! so this does not concern me too much.
I know doing this upgrade is a massive challenge but i have no intension in the next few years to change my car as mechanically it is in tip top condition (has only done 60k miles) and has been well serviced and is pampered by me. I am also aware that i will need to do some modification to the dash and centre console as the 2009 model has the electronic hand brake and mine doesn't and the terrain response system wont function (this is assumed as it is a different engine/transmission)
I apologise for such a long first post but after reading most of the posts on this forum there are some real experts on here that know these vehicles electrics inside out and if anyone has any ideas about this project i would love to here them!
Thanks for all your help in advance!
Matt
Post #44198 2nd Jan 2011 1:09pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
I am not technical so excuse the lack of input but I rather hoped you could send me some of what you are smoking?
Very Happy Very Happy Very Happy
Seriously, the cost of your time, the cost of parts, the mashed up result, the value of what you are left with don't make any sense. When you look at what owners are bid for mint 2007 s/c cars, a private purchase has to be the way to go. Also your car will be off the road for weeks.
I would lay dollars to doughnuts that the price to move from your car and buy a mint 07 for less money than you'll be able to assemble the pieces (unless you have a mate who is a car theif).
Post #44200 2nd Jan 2011 1:26pm
dan_uk_1984
Wow, that certainly is ambitious. I can se where you're coming from, there are a lot of nice interior touches in the newer models.
Personally though I would be worried about the stack of things that will be left over that just wont work. The terrain response dial being one, the off road display on the screen being another. I also thought the seats were different? They adjust differently, so I doubt they will be plug and play as I imagine they will need a different ecu to plug into (although you will have this).
I think the light control module will be different, and will require a new combined rain & light sensor as a minimum, the 2009 will have adaptive lights, this will not function.
You would also have to look at the resale value, this certainly isn't going to increase the value - although I appreciate you may be intending on keeping the car for a long time so this is less important.
There are many things you could look at as an alternative - but in reality I think the tech in the dash is going to be the hardest thing to change.
There is further info here which you may have already found:
http://www.fullfatrr.com/forum/topic2737.html
http://rangerovers.net/forum/viewtopic.php...nt+upgrade
Either way if you do it, take photo's and notes!
Post #44201 2nd Jan 2011 1:27pm
mattstevenson2005
Hi Dan, thanks for your comments, yes the terrain response dial is one of the things that may not work, although i am hoping that with alot of work and use of my knowledge and my MSV2 i will hope to eventually to try and get this work (or at lease get the HDC and air suspension buttons to work) to start with i will be leaving the bottom centre console panel in place so i could continue to control the EAS modes. The 2009 seats still run on the BMW ibus network even in the 2009 model so hopefully with a bit of work these will work just as they do now. My only concern with the seats is the SRS system, same as the airbag in the dash. The light control module (LCM) is the same as what is in the 03 model (apart from it is a different revision) so with changing the LCM from the 09 car into the 03 car there should be no problems also transplanting the rain/light sensor and light switch in to the 03 car will give me auto lights which i don't have now. I forgot about this feature my car has had the 07 front and rear facelift so my car has the adaptive lights fitted already so in the future this could be a separate project to enable this function on my 03 car.
Resale value is not a concern for me as even leaving the car in is current state (which is absolutely mint inside and out!) will still drop like a stone over the next few years even more so when the 'new' 2012 range rover comes out.
I have read both those forum posts over and over again in the preparation to this project, Colin's ambition is to get all aspects of the entertainment system working with his current 03 model e.g. 4x4 screen etc... so i am hopeful that once Colin figures it all out i can just follow his lead.
If i do go ahead with this project i will post all the details and photos on my website www.myrangerover.co.uk
Thanks again
Matt
Post #44203 2nd Jan 2011 1:46pm
dan_uk_1984
It's also worth noting that the LCM stores a copy of the Mileage data - so as long as you get the binnacle and the LCM from the same donor car you "should" be OK. However, I have heard than the ECM also stores mileage data, but this is un-verified so far.
Interesting about the seats, as I thought they were more jag based, especially when they introduced the cooled option. Who did you front end conversion, or did you do it yourself? Did you manage to keep the stock air filter or did you have to change it to a cone type?
Dan
Post #44208 2nd Jan 2011 2:41pm
mattstevenson2005
Dan
Hi Dan
I will be getting both the LCM and binnacle from the 2009 car but as far as i am aware you can't use the new 07+ shape binnacle on a 03 engine ECU (not 100% on this though, would like to use the newer binnacle but i am assuming this cannot be done, but would love to be proven wrong!!) with regards to mileage data i remember reading somewhere that the actual key/binnacle/LCM and EMC stores the mileage data and if the binnacle and LCM readings dont match you get a black dot on the screen indicating that they may be a discrepancy between the 2 ECU's. I was hoping that once i connect the donor LCM up to the car it would take the readings from my current binnacle as it will have a higher millage than the donor LCM unit. This is the same procedure that happens when replacing a damaged binnacle the replacement unit takes the highest millage recorded on in the car.
The seats in the donor car are heated only and use the same control panel in the centre console as my current seats so im hoping for a simple plug and play option. The front end conversion was already done on the car when i purchased it and it dose have the cone type air filter. Another project on my list is to 'construct' as bulk head between the engine and the air filter to prevent the engine sucking in warm air, but this is for another time.
Matt
Post #44212 2nd Jan 2011 2:58pm
dan_uk_1984
Matt
The reason I ask about whether you did the conversion or whether it was a rip off merchant... is because whoever did mine (before I bought it) and put the cheapest possible lights in. So are you 100% sure you have adaptive lights?
Mine should have bi-xenon, but they only fitted Xenon, then sold my Bi-Xenons... as well as a load of other bodges.
I'd be interested if the door cards are a strait swap - I prefer the newer door cards to mine...
Post #44216 2nd Jan 2011 3:03pm
the gear shift on the 2003 is in the middle so the later console wont fit as the shift is more to the driver..
btw , are you the matt from rr.net.. ... - .- -.
Post #44218 2nd Jan 2011 3:10pm
mattstevenson2005
Hi scarey, yes im Matt from rr.net and Landyzone, I have though about that problem too, the reason it is more to the drivers side is because the centre console reinforcement has a slightly different design so swapping the actual reinforcement for the centre console to the 09 one will allow me to mount my gear shift on the drivers side then i will modify the electronic parking brake area to allow my manual parking brake to come though when the e-brake button is. I will double check the spec on the lights.
With regards to the door cards, it should be a straight swap as the buttons on all the doors are the same from 02-11 and the 09 car is essentially the same as the 02 in regards to shape. e.g 02 door cards are same as 09 etc....
Matt
Post #44220 2nd Jan 2011 3:36pm
thought is was you, welcome mate....
you've got a massive project there and i hope it goes well.. ... - .- -.
Post #44226 2nd Jan 2011 4:01pm
mattstevenson2005
cheers scarey!! thanks for the welcome!
if i do start this project i will post all about it on my site.
Matt
Post #44227 2nd Jan 2011 4:27pm
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
the door cards are different in the later model due to the airbag being in the seat and no longer in the door , but they will fit, you just have to figure out how to wire the seat airbags up and remove the unused ones out of the door 2002 td6 vogue, 06 supercharged facelift
Post #44242 2nd Jan 2011 8:01pm
dan_uk_1984
Ah really? That's a pain.
Post #44243 2nd Jan 2011 8:11pm
mattstevenson2005
im going to purchase a subscription to Topix so i can take a look at all these little details and i can start to work out my game plan for the upgrade and i can compare the wiring diagrams from the 03 to 09 models
Matt
Post #44245 2nd Jan 2011 8:21pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Not to chuck a damper in, but if you are going to start playing with airbags, construction and use will rear it's ugly head. You can't mess with the safety systems of a modern car and expect your insurance company to play ball....
Could be a very expensive experiment, especially as some insurers are hiking premiums just for front end light upgrades.... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #44248 2nd Jan 2011 8:57pm
Page 1 of 3 123>
