Home > In Car Electronics (L405) > sim card |
Lutonboy Member Since: 26 Dec 2016 Location: Bedfordshire Posts: 35 |
Normally you have to push it in a little beyond the spring resistance of the slot to engage the catch, but it always struck me as being a little bit flimsy, which I noted when I inserted mine. |
14th Jun 2017 4:22pm |
DrDill Member Since: 08 Apr 2017 Location: Cornwall Posts: 66 |
hi, yes tried that it just wont stay in
14th Jun 2017 4:44pm |
stillrunning Member Since: 10 Jan 2017 Location: Cheshire Posts: 268 |
I had this issue but for me it was the wrong way round
14th Jun 2017 6:23pm |
I have tried all different ways. |
14th Jun 2017 6:58pm |
It appears i did not try properly. Salesman came out and inserted correctly and it stayed in! |
15th Jun 2017 7:02pm |
Oh matron lol
15th Jun 2017 9:31pm |
Well the cards now stays in. But the car cant read the sim, error says sim card removed!
17th Jun 2017 5:31pm |
1strangerover2017 Member Since: 11 Jun 2017 Location: Cambridgeshire Posts: 76 |
I had a similar issue with inserting the card and finally went in, in my opion the wrong way around, but I think I had to do something with the setting ( think I used the small leaflet with the handbook ), also may need to swop the metal connector the other way around, try the new card first, hope this helps |
17th Jun 2017 10:55pm |
New sim card bought and inserted. Still doesnt work. Says its reading card then says sim card not inserted.
20th Jun 2017 8:54pm |
w8pmc Member Since: 30 Oct 2016 Location: West Lancashire Posts: 229 |
Had an issue getting the right size of SIM card, but once received it did work from the off. Is the feature switched on within Incontrol? Paul
21st Jun 2017 8:39am |
Sim card is right size and it pushes in and stays in. From with in the incontrol system i select to turn on data and it reads sim fir about 5 minutez then says sim removed! |
21st Jun 2017 8:52am |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 |
Put the sim in a phone or tablet to prove it works on data . My Vodafone data only sim needed this before it worked in the car. |
21st Jun 2017 1:38pm |
Okay thanks. Will try that later
21st Jun 2017 1:44pm |
Sim card still not working. Dealer niw going to replace card reader.
4th Jul 2017 8:28pm |
