![]() | Home > In Car Electronics (L405) > sim card |
| Lutonboy Member Since: 26 Dec 2016 Location: Bedfordshire Posts: 35
Normally you have to push it in a little beyond the spring resistance of the slot to engage the catch, but it always struck me as being a little bit flimsy, which I noted when I inserted mine. |
| DrDill Member Since: 08 Apr 2017 Location: Cornwall Posts: 66
hi, yes tried that it just wont stay in
| stillrunning Member Since: 10 Jan 2017 Location: Cheshire Posts: 268
I had this issue but for me it was the wrong way round
I have tried all different ways. |
It appears i did not try properly. Salesman came out and inserted correctly and it stayed in! |
Oh matron lol
Well the cards now stays in. But the car cant read the sim, error says sim card removed!
| 1strangerover2017 Member Since: 11 Jun 2017 Location: Cambridgeshire Posts: 76
I had a similar issue with inserting the card and finally went in, in my opion the wrong way around, but I think I had to do something with the setting ( think I used the small leaflet with the handbook ), also may need to swop the metal connector the other way around, try the new card first, hope this helps |
New sim card bought and inserted. Still doesnt work. Says its reading card then says sim card not inserted.
| w8pmc Member Since: 30 Oct 2016 Location: West Lancashire Posts: 229
Had an issue getting the right size of SIM card, but once received it did work from the off. Is the feature switched on within Incontrol? Paul
Sim card is right size and it pushes in and stays in. From with in the incontrol system i select to turn on data and it reads sim fir about 5 minutez then says sim removed! |
| charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174
Put the sim in a phone or tablet to prove it works on data . My Vodafone data only sim needed this before it worked in the car. |
Okay thanks. Will try that later
Sim card still not working. Dealer niw going to replace card reader.
