![]() | Home > Technical (L322) > 2009 interior upgrade for my 2003 ffrr |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
Hi Daveo, yes you are correct about the rare 'gateway ecu' P/N YWC500422 but you should be able to get one of these from a land rover dealership for around £300. The gear shift is not actually physically attached to the gearbox it is bolted to the centre console reinforcement and a cable is attached to the gearbox to allow the gear shift to operate. The 09 centre console reinforcement will allow it to be move, the only issue with this is the manual hand brake needs to be accommodated, which should be possible with the removal of the 09 e-brake control (along with a bit of custom trim modification) With regards to the nav unit Colin from Blackbox Solutions is currently working on this project to 'transplant' the touch screen infotainment system into the earlier vehicles, but as i would be swapping my current dash and dash reinforcement for the 09 on the 09 dash will fit just as it does in the original 09 vehicle.
So you are not going to a 2010MY interior, but a 2006-9 interior without the TFT dash? Just so I am following this correctly..... Land Rover Addict
Yes you are correct im going to the 09 spec (pre-TFT dash) - upgrading to anything after 09MY is not possible at the moment as all Range Rovers that are built with the 10MY spec now use the CAN bus network for communicating between its ECUs and the majority of the BMW communication buses have now been removed, meaning our existing ECU's would not be able to communicate correctly. The most common item that people would won't to use in their pre 10MY vehicles is the redesigned steering wheel controls, which now runs on the CAN bus network, where as pre 10MY the buttons still operated on the traditional BMW ibus network, on the 06/07+ vehicles the instrument cluster is used as a gateway between the CAN and iBus networks. This is why the infamous 'gateway ecu' in the 2005 version is so rare as when Land Rover did the upgrade in 06/07 this temporary CAN bus gateway was replaced by the re-designed instrument cluster which incorporated this essential ECU. When BMW sold Land Rover to Ford, Ford wanted to replace the BMW infotainment system with a denso unit which is also used in the higher end Ford (among other vehicle manufactures) models so they designed a temporary 'gateway' ECU to translate the iBus commands of the BMW systems into their standard CAN commands which the new infotainment system uses to communicate. Matt |
Hmmm well tbh, I wouldn't attempt the change, I had a 2004, a 2006 and now a 2010. The only major change was the 2010. I don't think it is worth the pain to change the entire interior, and the 2009 seats are *worse* than the 2002-2006 BMW ones......
The reason i want to change the interior is because i much prefer the look of the upgraded interior over the 03 spec one. I was originally contemplating another in car pc (i have already had one in my previous car) but i decided against it as i like things to looks original as possible and doing the 09 upgrade gives me an original factory look with the upgraded infotainment system over the 03 spec. In the future i could do a in car pc on the touch screen system as you can use a VGA input converter to override the NAV display on the front screen. This is a very common upgrade on the RRS & Disco 3&4. A number of people have said about the newer shape seats, so I think i am going to make a trip to my local dealer to try the seats out for myself as i really do like the comfort of my current seats. Im very grateful for your comments because as you have said you have had every version of the L322 Range Rover and that gives me a great resource as you have 'lived' with the interior that i am looking at upgrading too. Hows the 2010 V8 to drive, that is the model i would most like to have - if i won the lottery i would be down the dealership placing an order straight away!! Matt |
I really would check out the seats, also look at one with about 40,000 on the clock and notice the damage ... the leather is softer. They do not have the same amount of adjustment as the pre-2007 either. I was lucky that my 2006 was an early one with the manual handbrake etc, and BMW seats still. 2004 and my 2006 had more comfortable seats than my 2010.
matt, so you are going with the 09 steering wheel controls, now are thes the same as the earlier models or as they started fitting the new style steering wheel controls with the 4 way thumb swithes at the top, as these are what i have and was told they are can bus. V8 facelift Range Rover Autobiography 22" wheels.
Daveo, if pre-2010 TFT etc, they will be as the 2006-2009 MY was..... Land Rover Addict
The ones that are on the current range rover model with the thumb switches at the top, run on the CAN bus network, any other model years e.g. 05-09 still use the BMW ibus network to send their signals to the instrument cluster gateway which sends it to the infotainment system (touch screen version) 02-04/05 (pre touch screen) the steering wheel buttons connect directly to the infotainment ibus network. |
Sounds ambitious, to say the least, Matt.
Hi mate, you are correct about the multiple CAN networks, but everything i want to add either runs on the existing networks or on the MOST bus for the infotainment system - the donor car i have is a front end smashed up 2009 so i am planning to just swap everything 'cosmetic' from the 09 to my 03. I have been talking with Colin because as im sure your aware he's doing the same project with putting the touch screen nav system into his 03 vehicle so he has some excellent experience in this field. My most difficult problem as mentioned in previous posts is the redesigned airbags e.g. in 02-05 side air bags are in the door, 05-09 they are now in the actual seats, and also the dash airbag has moved. Your also correct my plan is to try and stick with the original electrics and 'adapt' the new style switches to function with the existing systems. Apart from the MOST infotainment system everything else that will be transplanted from the 09 donor vehicle runs on either the BCU or LCM which can be simply swapped from the 09 vehicle and re-configured using my MSV2-Extreme from Blackbox. Matt |
That's a bit of a problem, tho.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I stopped reading at the 2nd paragraph and I'm a time served engineer!
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
Matt,
