![]() | Home > Technical (L322) > 4.4 TDV8 MAP sensor |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3864 ![]() ![]() ![]() |
I don't think mine has been cleaned in it's 66k mile life.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
I hope that was after and before? |
Mpirie 👍👍, sorry dyslexic picture posting. !! G reg 2.5VM Vogue Portofino red 1991- 1999
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Electric contact cleaner you say?
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
brake cleaner, cheaper |
Have both in he garage |
Definitely brake cleaner.....way better and cheaper! |
My dirty sensor...
same as mine, except the color was more gray on mine. if you have not clean the throttle butterfly yet now is the time. |
NMJ,
I opened mine up for a good blast on the M62 last night and it was pulling like an express train,
Nino can you post some pictures of cleaning the butterfly please. Do you lubricate it with anything? G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
Could a dirty choked up sensor cause a restricted performance issue? Current: TDV8 (3.6) RRS HSE
