Home > Technical (L322) > Another reduced performance!
Will get some on order👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #443194 1st Jul 2017 10:44am
Baltic Blue
I am not convinced that mine was actually split.
3 ports were spotlessly clean, and one was sooty black.
It could have just been loose ?, but the MDjust said we will replace them, so I didn't argue. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443195 1st Jul 2017 11:04am
Baltic Blue
Learning to use skitch.
Air change over valve.
Post #443196 1st Jul 2017 11:15am
nino_nino
this is my air change-over valve . is this "new" or "old" style? i did apply vacuum and it moves.
Post #443209 1st Jul 2017 3:04pm
Baltic Blue
With nut is old.
Plain shaft is new (modified). G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443211 1st Jul 2017 3:37pm
Baltic Blue
NMJ,
Took picture of hoses whilst out "messing" cleaning my MAP sensor.
No ridges, but if you look at the picture of the removed manifold on the MAP thread, you can clearly see the ridge on the original.
Post #443212 1st Jul 2017 3:43pm
Definitely different from mine.
They seem to have changed them from simple rubber items to something more akin to the reinforced turbo hoses. There is nothing that can't be fixed with a hammer😜😜
Post #443215 1st Jul 2017 4:16pm
nino_nino
here are my hosis,quite a difference.
Post #443218 1st Jul 2017 4:24pm
^beat me to it, same as mine. There is nothing that can't be fixed with a hammer😜😜
Post #443219 1st Jul 2017 4:26pm
stu
Well I've had a look around whilst servicing the FF today and I have as far as I am aware 3 old style manifold rubbers and 1 new one (pictures refer) and I have the older nut type air change valve.
What exactly does this do and how hard would it be to change, anyone done it?
 Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443220 1st Jul 2017 4:44pm
Baltic Blue
My change over valve was replaced by M D, but technical Bulletin says 1.1 hours work.
You have to remove the plastic tray from under the engine and access it from underneath, so jacking up front end and axel stands required. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443226 1st Jul 2017 5:03pm
stu
How do you make this actuate? I don't quite understand what this is for?
I'm just going to give things a day or two to see how I get on and whether the restricted performance comes back. All the manifold rubbers seem ok. Just want to see the valve actuate.
Need to clear my DPF fault first. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443229 1st Jul 2017 6:08pm
