![]() | Home > Technical (L322) > Another reduced performance! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3853 ![]() ![]() ![]() |
I am not convinced that mine was actually split.
Learning to use skitch.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
this is my air change-over valve . is this "new" or "old" style? i did apply vacuum and it moves.
With nut is old.
NMJ,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Definitely different from mine.
here are my hosis,quite a difference.
^beat me to it, same as mine. There is nothing that can't be fixed with a hammer😜😜
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
Well I've had a look around whilst servicing the FF today and I have as far as I am aware 3 old style manifold rubbers and 1 new one (pictures refer) and I have the older nut type air change valve.
My change over valve was replaced by M D, but technical Bulletin says 1.1 hours work.
How do you make this actuate? I don't quite understand what this is for?
