Home > Technical (L322) > Active Suspension Failure
nbunney
I've had the Active Suspension Failure msg on the dash since the 27th. It was being used that day, then suddenly stopped.
Checked fuses / block in the footwell, all OK.
Now the lights have gone out on the height adjuster / indicator.
Strange Rolling Eyes
Oh it's on the TD6 by the way.
Post #44407 3rd Jan 2011 9:40pm
obvious question nigel, how's the battery? ... - .- -.
Post #44418 3rd Jan 2011 10:46pm
nbunney
Scarey
Battery is a good 1, no starting issues etc.
Just odd the dash indicator lights went out when I checked both fuses / connector in the footwell.
Post #44419 3rd Jan 2011 10:48pm
sounds like you moved/touched something whilst doing that..maybe a fuse has been loosened... ... - .- -.
Post #44420 3rd Jan 2011 10:50pm
dan_uk_1984
Can I check you mean Active Suspension Failure, or did it say Air Suspension Inactive?
Post #44424 3rd Jan 2011 11:25pm
igore
England 2002 Range Rover Vogue Td6 Adriatic Blue
mine done that and all it was , was a wire had come loose from the EAS ecu. Cool ONE LIFE LIVE IT
Post #44444 4th Jan 2011 8:13am
nbunney
Dan
Air Suspension Inactive Thumbs Up
Post #44448 4th Jan 2011 10:31am
RRRob
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
I have had that fault several times ranging from water in a ride height sensor to a new compressor needed. Needs to be plugged in to tel I would say .
Post #44468 4th Jan 2011 12:55pm
igore
great pics rrob Thumbs Up ONE LIFE LIVE IT
Post #44643 5th Jan 2011 12:35pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Now i wonder how you got water in your ride height sensor... Laughing 2004 black Vogue TD6
Post #44644 5th Jan 2011 1:07pm
