Home > Technical (L322) > Active Suspension Failure
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
I've had the Active Suspension Failure msg on the dash since the 27th. It was being used that day, then suddenly stopped.
Checked fuses / block in the footwell, all OK.
Now the lights have gone out on the height adjuster / indicator.
Strange Rolling Eyes
Oh it's on the TD6 by the way.
Post #44407 3rd Jan 2011 9:40pm
obvious question nigel, how's the battery? ... - .- -.
Post #44418 3rd Jan 2011 10:46pm
nbunney
Scarey
Battery is a good 1, no starting issues etc.
Just odd the dash indicator lights went out when I checked both fuses / connector in the footwell.
Post #44419 3rd Jan 2011 10:48pm
sounds like you moved/touched something whilst doing that..maybe a fuse has been loosened... ... - .- -.
Post #44420 3rd Jan 2011 10:50pm
dan_uk_1984
Can I check you mean Active Suspension Failure, or did it say Air Suspension Inactive?
Post #44424 3rd Jan 2011 11:25pm
igore
England 2002 Range Rover Vogue Td6 Adriatic Blue
mine done that and all it was , was a wire had come loose from the EAS ecu. Cool ONE LIFE LIVE IT
Post #44444 4th Jan 2011 8:13am
nbunney
Dan
Air Suspension Inactive Thumbs Up
Post #44448 4th Jan 2011 10:31am
RRRob
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
I have had that fault several times ranging from water in a ride height sensor to a new compressor needed. Needs to be plugged in to tel I would say .
Post #44468 4th Jan 2011 12:55pm
igore
great pics rrob Thumbs Up ONE LIFE LIVE IT
Post #44643 5th Jan 2011 12:35pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Now i wonder how you got water in your ride height sensor... Laughing 2004 black Vogue TD6
Post #44644 5th Jan 2011 1:07pm
