![]() | Home > Technical (L322) > Active Suspension Failure |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2068 ![]() ![]() ![]() |
I've had the Active Suspension Failure msg on the dash since the 27th. It was being used that day, then suddenly stopped.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
obvious question nigel, how's the battery? ... - .- -.
Scarey
sounds like you moved/touched something whilst doing that..maybe a fuse has been loosened... ... - .- -.
Can I check you mean Active Suspension Failure, or did it say Air Suspension Inactive? |
igore Member Since: 20 Oct 2010 Location: portsmouth Posts: 118 ![]() ![]() ![]() |
mine done that and all it was , was a wire had come loose from the EAS ecu. |
Dan
great pics rrob |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
Now i wonder how you got water in your ride height sensor... ![]() |
