Home > Technical (L322) > owners of IID tool...does it show DPF information? - UPDATE
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Esteemed IID owners,
Please can you tell me if there is any menu option or parameter(s) related to the DPF?
I have just replaced the DPF in my car (I have a whole separate thread on that!), but as others suggested, the cars ECU still throws out the DPF full message (with restricted performance) and WILL until the error is cleared by a suitable tool.
Now I thought that it was going to be straightforward ....clear all errors and off we go. But it has been suggested to me that it is NOT that simple and that you can't just clear the error, you have to "programme" the ECU with some basic parameters to tell it that it has a new DPF fitted.... Sad
(please no comments about regenerations / read the manual / etc etc - this isn't about that - we are way beyond that) - I just want to know will clearing all error codes be enough after fitting the DPF or is there a "set up" procedure for a new DPF in the diagnostics)
Thanks
Post #447742 13th Aug 2017 9:50pm
Baltic Blue
I am a novice with the iid tool, but will plug mine in and take a screenshot of any mention of DPF that I can find.
Hope you get it sorted soon.
Cheers. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #447767 14th Aug 2017 8:37am
theres this in the live values bit,
DPF Diff Pressure Sensor V
DPF Remaining Volume ... - .- -.
Post #447770 14th Aug 2017 8:56am
Fleagle_UK
thanks Stan.
does it look like those parameters are user changeable or is it just read only of the live data?
The pressure sensor one I understand - and perhaps doesn't worry me - it will be measuring the live delta between pressure fore and aft of the DPF - in other words "how blocked is the DP? / what is the current back pressure"
The interesting one is the "remaining volume" - that I wonder if that has to be re-programmed to a value somehow.
If any one knows or can help...
Many Thanks.
Post #447774 14th Aug 2017 9:43am
Fleagle_UK
spoke briefly to support at GAP. They confirmed that the current firmware on the IID DOESN'T change / clear DPF data but they can talk me through upgrading it so that it does!!
What nice chaps! Thumbs Up
Post #447919 15th Aug 2017 12:06pm
did GAP tell whats involved in this process.. ... - .- -.
Post #447921 15th Aug 2017 12:15pm
Fleagle_UK
not yet Stan.
Patrick at GAP said he would give me instructions once I had received my unit - ( Dan @Duckworths is sending me one tomorrow.)
Never used the tool myself so don't know where he will go with it - presumably new firmware.
Post #447926 15th Aug 2017 12:26pm
it will interesting to find out ....keep us up to date Wink ... - .- -.
Post #447929 15th Aug 2017 12:30pm
Baltic Blue
I fear it is only a matter of time before we will all need this update .
All credit to GAP, yet another example of their excellent service. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #447932 15th Aug 2017 12:43pm
Fleagle_UK
DPFs are a ticking time bomb thats for sure.
- clearly a great marketing scam to secure even more future maintenance revenues from drivers.
Post #447935 15th Aug 2017 1:20pm
Fleagle_UK
OK firmware special build 2351 - contains the DPF reset function for TDV8s.... and it works!!!!!! Very Happy Very Happy Very Happy Laughing
happy days...I have a car that works again!
Got to say the guys at GAP are awesome in their customer support! Bow down :thumbs:
( I should add that the special build 2351 isn't a certified release yet.. - so use it for other things at your own risk Shocked )
Post #448128 17th Aug 2017 3:17pm
that's great news Thumbs Up
i suppose the dpf reset is vin specific... ... - .- -.
Post #448133 17th Aug 2017 3:25pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Resurrecting an old thread.
Is the DPF reset a min menu item yet because it would encourage me to buy an IID Tool if it is.
Thanks
David 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #505932 21st Feb 2019 7:05pm
Fleagle_UK
Last i looked a few months ago, the folk at GAP havent done any software updates for quite some time. 😒
When they did the special version for me i immediately reverted back to standard release after doing the job.
Post #505945 21st Feb 2019 8:44pm
