![]() | Home > Maintenance & Mods (L322) > Battery conditioner - £12.99 |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
goes up to 120amps so it'll do the RR battery so it sounds ok.... |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
The cigarette lighters shut down after a few minutes of the ign being off.
| EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181
Dan - you are a genius - I'll look into it but I had not noticed the area - what capacity battery would I need purely as an emergency starter?
I wouldnt use it as a seperate battery - I would just use it to provide extra "reserve" for the system. The + cable isn't heavy duty enough to start the car if the main battery was flat. But the idea is that you'd have to try REALLY hard to make both batteries so flat that combined they couldnt start the car.
just a thought ed, have you considered a new battery...you should'nt [in theory] get any problems then... |
LR fitted a new one after a week of ownership (a common problem with new owners tinkering) in July. The CTEK gismo certainly reads well and is recommended by Aston, Ferrari and others to keep ones wagon tip-top. The chap that suggested it to me said his battery was 7 yrs old - way past what I thought was typical. '96 Volkswagen Polo 1.4CL - SOLD
was it the correct size/amp battery fitted....should be 110ah with a 920 crank.. |
In theory a well maintained battery shouldn't need replacing ever. But deep discharges damage the battery, every time it runs flat it looses capacity to hold a charge due to fast deterioration of the lead plates.
| dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477
Don't think they shut down Dan, I've read somewhere that they are both a permanent live: I've also used the socket in the boot to charge a phone for a couple of hours whilst away from the car. |
Excellent - that's good to know for things like fridges in the boot - ie remember to unplug them.
| Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181
From October 28 to December28 my car has sat on the drive undriven. I had concerns about battery drain that i had heard about occurring on 2010MY cars so the car has sat with a Maplins solar powered battery top-up charger plugged into the cigarette lighter. On 28th Dec my brother took the car out for a run and reported back that even though it was -10 outside the engine fired as soon as the glow plug light had gone out - he had also used the Park Heat to try and defrost the car. The amazing thing is that this little charger has not required direct sunlight on it - it has continued to top up the battery even when the front screen (it sits on top of the dash) is covered with ice or snow. There is a blue flashing LED that indicates that it is putting charge into the battery and it has safety circuitry built in to prevent battery over-charging. Here you go - it took an age to down load the page but here's the link http://www.maplin.co.uk/module.aspx?moduleno=98358 and at a price suitable for most FFRR owners too |
i know someone who has this kind of gadget on his motor home which isnt used much at the moment and he reports the same as you TIM...could be ideal for anything thats not used much.. |
| Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313
For those that are interested, twin battery set up here:
| All times are GMT |
