Home > Technical (L322) > Tapping sound
Danwilderspin
Tapping sound
Any ideas what this could be?  Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #452621 1st Oct 2017 12:09pm
gizze
I the coolant level OK?
No leaks at all?
No water near the bleed screw?
It could be something simple like air in the water pump. Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #452624 1st Oct 2017 1:05pm
holidaychicken
Re: Tapping sound
Unnecessary quote removed
I know what that is, it's a really short clip giving nobody a chance of helping you find out what it is !! Very Happy
Post #452677 1st Oct 2017 11:41pm
Danwilderspin
I will take a longer one but it’s soumds like a tappet do they go on these? If you rev it it goes faster - what’s the procedure for fixing? Thanks Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #452795 2nd Oct 2017 10:15pm
holidaychicken
Try moving your phone around next to various parts of the engine rather than the wheel but the M62TUB44 engine that we both have is notorious for tapping.
Sometimes it is nothing more than a lifter that needs bleeding if the vehicle stands around a lot and this can be achieved by elevated revs for 2 minutes I think it is at something like 3000 rpm or I just take mine for a bit of sport mode driving.
HOWEVER, these engines also suffer from timing chain guide failure which isn't always fatal but the above procedure if it's the guides will most likely make it terminal.
They also suffer from vanos wear which normally manifests as start up rattle and then tapping when the engine is warm.
It could also be a lose spark plug or leaking exhaust manifold or even a failing torque converter depending on where the noise is coming from or even mechanical failure of one of the engine components or just low oil level or the wrong oil type or a failing oil pump or a blocked oil way or failing water pump ....
Or none of the above...
When did it start and is it present all the time ?
Post #452805 2nd Oct 2017 11:59pm
fisha
they also have VANOS as well I think, which is gubbings within the cylinder heads which is known for tapping too.
when was the last oil change. My old 4.4 BMW unit would tap on startup sometimes ... but I found it varied with oil life and temperature. V8 or else ...
Post #452828 3rd Oct 2017 9:16am
Danwilderspin
Here is a better video  Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #453400 9th Oct 2017 6:47am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Jamie Oliver's sous-chef trying to get out??
Post #453424 9th Oct 2017 11:18am
Danwilderspin
lol oh dear,,, Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #453425 9th Oct 2017 11:20am
holidaychicken
Does it do when the engine is first started / cold?
Post #453457 9th Oct 2017 3:16pm
Danwilderspin
all the time marginally louder on startup Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #453465 9th Oct 2017 3:28pm
holidaychicken
It sounds like mine, mine starts off loud on startup and if I leave it to warm up it goes away.
If your oil is at the maximum level then I think like mine it is the hydraulic lifters, if you Google BMW M62 lifter noise or tapping or ticking the internet is a wash with videos and threads.
There is a procedure to bleed the tappets which may work providing everything else such as oil type - another mine field, is ok, however and it's a fairly big however, if the problem was timing chain guides then the procedure could kill the engine.
Timing chain guides failing is normally a harsh metal on metal sound and the bits of plastic guide end up in the sump so removing the lower sump is a fairly conclusive way to tell.
Vanos failing normally sounds like a loud start up rattle then a ticking noise once the engine gets warm.
Have a goigle and drive yourself insane with the rest of us.
http://forum.bmw5.co.uk/topic/45630-the-in...ingtappet/
Post #453519 9th Oct 2017 7:19pm
