|  | Home > Technical (L322) > Question about a/c and auto heating |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | Mines always on..... I would have thought it would keep the last setting when started up.... never tried....
|  5th Nov 2017 9:44pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | It sort of remembers last setting. But can be a bit hit and miss.
|  5th Nov 2017 10:01pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | One is auto fan and the other is auto distribution, ie face, feet etc. Can’t remember which. If you have both lit and you move the fan speed manually, the auto fan goes out, so you will know.... press the middle of the button to cycle through.... 2011 Range Rover Vogue SE 4.4 TDV8
|  5th Nov 2017 10:17pm |
| Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147      | With temp set at 28c the heater will come on  | ||
|  6th Nov 2017 8:04pm |
| umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433      | Yes but why the ac also on every time?
|  16th Nov 2017 7:36am |
| GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670      | Mine always starts with the rear blower activated.
|  16th Nov 2017 11:05am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | try putting it all in manual mode,
|  16th Nov 2017 11:14am |
| umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433      | What is rear blower?
|  16th Nov 2017 1:58pm |
| GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670      | Yes, the rear climate.
|  16th Nov 2017 2:25pm |
| GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670      | Thanks, Stan.
|  16th Nov 2017 2:27pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | hopefully....
|  16th Nov 2017 3:39pm |
| GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670      | Thanks again. Will give it a go later. What do I put here then? | ||
|  16th Nov 2017 3:45pm |
| Posting Rules
