Home > Technical (L322) > Question about a/c and auto heating
Gumball3000
United Kingdom 2011 Range Rover Vogue SE TDV8 Zermatt Silver
My 2011 L322 FF turns on the a/c and puts the heating on auto every time i start the engine.
I have looked in the handbook but cant see anything regarding turning it off.
Can it be done ?
Cheers
Paul
Post #456262 5th Nov 2017 7:05pm
mjdronfield
Mines always on..... I would have thought it would keep the last setting when started up.... never tried....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #456295 5th Nov 2017 10:44pm
GGDR
It sort of remembers last setting. But can be a bit hit and miss.
While we're on the subject does anyone know what the lights in the middle of the blower knob signify?
There is a round LED and a lozenge LED, I've looked in the manual, but couldn't see anything.
(Might have male-manual-blindness though)
Greg Cheers, Greg
Post #456297 5th Nov 2017 11:01pm
mjdronfield
One is auto fan and the other is auto distribution, ie face, feet etc. Can’t remember which. If you have both lit and you move the fan speed manually, the auto fan goes out, so you will know.... press the middle of the button to cycle through.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #456301 5th Nov 2017 11:17pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
With temp set at 28c the heater will come on Question Question 2012 TDV8 Vogue SE 4.4
Post #456385 6th Nov 2017 9:04pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Yes but why the ac also on every time?
I turn off completely but iti is on at every start.
Wasnt same at 2006 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #457456 16th Nov 2017 8:36am
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Mine always starts with the rear blower activated.
Would prefer the default to be it off.
Is there a way? What do I put here then?
Post #457483 16th Nov 2017 12:05pm
try putting it all in manual mode,
ac off
temp at 16
blower on one
direction of air flow to top
press memory button on seat [now this is probably nothing to do with the heat settings but try it]
run like this with the engine on for a few minutes..
stop,lock and hope it will be the same when you next enter... ... - .- -.
Post #457486 16th Nov 2017 12:14pm
umitbat
What is rear blower?
Is it the rear seat climate console ? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #457515 16th Nov 2017 2:58pm
GAC23
Yes, the rear climate.
As I'm sure you know, there's a button below the heating controls in the front where you can activate / deactivate the rear.
Would like mine to default to don't use rear if possible. What do I put here then?
Post #457517 16th Nov 2017 3:25pm
GAC23
Thanks, Stan.
And if it is ... does this mean it'll then remember how I had it set - ie with aircon on auto - next time I turn it off? What do I put here then?
Post #457518 16th Nov 2017 3:27pm
hopefully....
when i got mine it took a few tries to get it to stay on manual... ... - .- -.
Post #457523 16th Nov 2017 4:39pm
GAC23
Thanks again. Will give it a go later. What do I put here then?
Post #457524 16th Nov 2017 4:45pm
