![]() | Home > Maintenance & Mods (L405) > Land Rover OEM flange tow bar question... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872 ![]() ![]() |
nut and bolt to replace the pin...
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 159 ![]() ![]() |
Unnecessary quote removed
Or put “receiver hitch anti rattle shim in google and a rather neat clamp thing comes up as an option! |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Thanks to each one of you! I will have a closer look at each one of these answers after work tonight |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818 ![]() ![]() |
All as above, if you don't want the rattle use the bolt. If you want speedy removal to keep the car looking nice and avoid theft then use the pin and R clip.
Thanks for all of the suggestions chaps |
Oh Sheet you know her as well!!!! |
That does look like a very neat solution |
Wait, there's more....
... and some of them will work on the FFRR - but not all of them unless they changed if for the L405......
Ah, I really am learning quickly here. I shall be out for an accurate measurement of my receiver in the morning (too cold and dark now!). |
The device you wanted will be fine - it's only things that need to fit into the receiver you need to be careful with |
