Home > Technical (L322) > Downhill jolt
Danwilderspin
Downhill jolt
So anyone following me will know I had gearbox issues last year when I bought the car - thankfully it had had a rebuild 10k before so wasn’t that and it turned out it just needs a service a new rad and a new gearbox Cooler and she’s been good as Gold since.
Now I live in the fens we don’t have any hills etc and for the first time in ages I’ve take here to Devon - now obviously over Dartmoor etc it’s quite hilly and I’ve noticed That when I let off the accelerator st speed and coast down a hill it’s fine but if I break and am still carrying some speed and trying to come to a standstill I get the whole car jolt - any ideas?[/i] Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #458836 28th Nov 2017 4:24pm
Danwilderspin
Also should add it idles very low 450-550 rpm max bit not lumpy seems to be ok - can this be increased? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #458889 28th Nov 2017 10:00pm
Dolphinboy
It will idle that low if the air con is off -should be c.700 with aircon on.
Post #458965 29th Nov 2017 11:24pm
Danwilderspin
Ok I always turn it off in this weather - is it more likely to jolt with it off? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #458967 29th Nov 2017 11:39pm
holidaychicken
Since I have owned mine I been trying to find the slack in my drivetrain.
If I accelerate normally, let the throttle off and then put it back on I get a bang or a clunk from underneath, it is play in the drivetrain but never managed to trace it.
I think on the later models it was eliminated by an engine and transmission ECU update.
If I have my air con on the revs don’t drop so much and I get less engine braking and so less backlash in the drivetrain.
There may be an ECU update that cures it but I’ve never tried it and there are companies that offer both engine and transmission updates for the M62.
I believe your idle without air con should be 600 rpm.
If you have a MAF problem or air leak the revs might drop lower.
I changed my MAF, rebuilt transfer box, outer front cv joints, none of which made any difference...
Post #458979 30th Nov 2017 12:23am
Danwilderspin
Hmm I had more issues initially when I got it and put it down to incorrect oil and blocked oil cooler - a google states this could be eas linked which isn’t right currently or a water pump on its way out...
Will do further checking![/i] Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #458982 30th Nov 2017 12:41am
holidaychicken
Your problem could be different to what I’m describing , there is also a transmission fault that I’ve heard of but can’t remember what caused it but I’ll havd a dig later
Post #458989 30th Nov 2017 6:46am
Dolphinboy
I think holidaychicken has hit the nail on the head with his drivetrain slack. If not that, then could be a brake issue if it only happens when you try to come to a fast halt. Otherwise could be a clunky gearbox change down which would need to be reset with a software input?
Post #458992 30th Nov 2017 8:29am
Danwilderspin
Hoping rrphil will chip in as it sounds like an issues he’s dealt with before.. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #458994 30th Nov 2017 8:36am
Danwilderspin
Ran with the ac on today and this made a massive difference wondering if running on lpg makes it idle a little lower than it should Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #459058 30th Nov 2017 6:28pm
holidaychicken
If you look for threads on harsh downshift in the x5 and l322 or ZF5HP24 it mentions software upgrade
something along these lines
https://xoutpost.com/bmw-sav-forums/x5-e53...pping.html
http://xdrivers.co.uk/forum/index.php?topic=1571.0
Post #459102 30th Nov 2017 10:21pm
Dolphinboy
Running on LPG should make no difference to the idle speed. Suggest you get a service on the LPG if that is making such a difference.
I still go with her software upgrade or drivetrain. You haven't said if it only happens when u brake .... in which case it is obviously ......
Post #459106 30th Nov 2017 10:55pm
Danwilderspin
Hi - I used to get harsh pull aways 1-2gear but a flush and all new gear cooling stuff fixed that nicely I thought all was well until these steep declines and it only happens if you brake hard and roll a bit it’s like 2-1 gear almost and it does feel almost like a near stall and start. Mine is an 02 so if it’s not been updated chances are it’s original - anyone had the firmware done in the l322? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #459114 30th Nov 2017 11:16pm
