![]() | Home > Technical (L322) > Downhill jolt |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2299
Also should add it idles very low 450-550 rpm max bit not lumpy seems to be ok - can this be increased? Current stable:
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
It will idle that low if the air con is off -should be c.700 with aircon on. |
Ok I always turn it off in this weather - is it more likely to jolt with it off? Current stable:
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
Since I have owned mine I been trying to find the slack in my drivetrain.
Hmm I had more issues initially when I got it and put it down to incorrect oil and blocked oil cooler - a google states this could be eas linked which isn’t right currently or a water pump on its way out...
Your problem could be different to what I’m describing , there is also a transmission fault that I’ve heard of but can’t remember what caused it but I’ll havd a dig later |
I think holidaychicken has hit the nail on the head with his drivetrain slack. If not that, then could be a brake issue if it only happens when you try to come to a fast halt. Otherwise could be a clunky gearbox change down which would need to be reset with a software input? |
Hoping rrphil will chip in as it sounds like an issues he’s dealt with before.. Current stable:
Ran with the ac on today and this made a massive difference wondering if running on lpg makes it idle a little lower than it should Current stable:
If you look for threads on harsh downshift in the x5 and l322 or ZF5HP24 it mentions software upgrade
Running on LPG should make no difference to the idle speed. Suggest you get a service on the LPG if that is making such a difference.
Hi - I used to get harsh pull aways 1-2gear but a flush and all new gear cooling stuff fixed that nicely I thought all was well until these steep declines and it only happens if you brake hard and roll a bit it’s like 2-1 gear almost and it does feel almost like a near stall and start. Mine is an 02 so if it’s not been updated chances are it’s original - anyone had the firmware done in the l322? Current stable:
| All times are GMT |
