![]() | Home > Technical (L322) > interior lights off |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
both your problems might be related to a dodgy battery...how old is it and has it been tested? |
thelandlord Member Since: 13 Jan 2011 Location: uk Posts: 10 ![]() ![]() |
hi allw as fine then the wing mirrors starting with the problems, then the battery died and had a new one fitted then the interior lights went off bingo |
could be a fuse or could be that you switched them off..i read somewhere that the FFRR interior lights can be switched of so that the battery wont be run down when you have all the doors open.[for whatever reason] |
hi yes tried that they went off just as i stopped and opened the door then neevr to return along with the puddle lights wing mirroe lights and the lock the dorr when you drive off thing thanks steve |
try dis-connecting the battery for 1/2 hour...make sure the car has been standing for about 20 minutes to let all the ecu's discharge before disconnecting the battery.. |
ok sounds good to me silly question disconnect both wires ?? |
no, just the one on the bulkhead... |
ok the one thast on the body covered by a plastic cover thing ? |
yarp.... |
great off i go then....lets hope it works.... |
forgot to mention, when the battery is re-connected , turn the steering wheel full to the left and then full to the right..this resets the steering parameters... |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Do the interior lights work when you open other doors? If so then the switch on the drivers door sounds funked Ian |
hi martin did that but still the same no lights except the little ones each side of the main light on the roof, when the doors open the lights dont come either strange eh of course the main dealer will say hes never seen this before !! |
hi when opening the doors any doors the inside lights do not come on |
