Home > Technical (L322) > interior lights off
thelandlord
2003 Range Rover Vogue 4.4 V8 Epsom Green
interior lights off
hi range rover vogue 2003 4.4 interior lights worked fine along puddle lights and wing mirror lights and the drive away locking, then one day bang they went, fuses all ok, bulbs all ok anyone any ideas please?interiors lights went off, puddle lights went off and drive away locking stopped working and now you can lock the car with the door open !! Censored
Post #45909 13th Jan 2011 4:56pm
both your problems might be related to a dodgy battery...how old is it and has it been tested?
Post #45911 13th Jan 2011 5:05pm
thelandlord
battery
hi allw as fine then the wing mirrors starting with the problems, then the battery died and had a new one fitted then the interior lights went off bingo
Post #45917 13th Jan 2011 5:22pm
could be a fuse or could be that you switched them off..i read somewhere that the FFRR interior lights can be switched of so that the battery wont be run down when you have all the doors open.[for whatever reason]
Post #45919 13th Jan 2011 5:34pm
thelandlord
a ha
hi yes tried that they went off just as i stopped and opened the door then neevr to return along with the puddle lights wing mirroe lights and the lock the dorr when you drive off thing thanks steve
Post #45921 13th Jan 2011 5:37pm
try dis-connecting the battery for 1/2 hour...make sure the car has been standing for about 20 minutes to let all the ecu's discharge before disconnecting the battery..
Post #45924 13th Jan 2011 5:47pm
thelandlord
ok sounds good to me silly question disconnect both wires ??
Post #45929 13th Jan 2011 6:53pm
no, just the one on the bulkhead...
Post #45941 13th Jan 2011 8:14pm
thelandlord
ok the one thast on the body covered by a plastic cover thing ?
Post #45949 13th Jan 2011 8:29pm
yarp....
Post #45953 13th Jan 2011 8:32pm
thelandlord
great off i go then....lets hope it works....
Post #45956 13th Jan 2011 8:37pm
forgot to mention, when the battery is re-connected , turn the steering wheel full to the left and then full to the right..this resets the steering parameters...
Post #45962 13th Jan 2011 8:56pm
T24RES
Do the interior lights work when you open other doors? If so then the switch on the drivers door sounds funked Ian
Post #45970 13th Jan 2011 9:08pm
thelandlord
hi martin did that but still the same no lights except the little ones each side of the main light on the roof, when the doors open the lights dont come either strange eh of course the main dealer will say hes never seen this before !!
Post #45973 13th Jan 2011 9:18pm
thelandlord
hi when opening the doors any doors the inside lights do not come on
Post #45974 13th Jan 2011 9:19pm
