![]() | Home > Technical (L322) > Which oil type 4.4 TDV8 ? |
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818
Greg, I used to go between 12k and 16k between services - yes used a tiny bit of oil (as all cars do and if anyone tells you any different they are lying). But I never needed to top up, I.e. The oil used was so minimal it didn't need topping up between services. I / the main agent used the advocated Shell Helix 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Thanks again chaps.
^Check engine fault codes^ there maybe a manifold temp probe gone which over fuels the car and fills the DPF 10X quicker than normal... |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
Greg,
Ok so last Saturday as you can read above I'm getting low oil, top up 0.5 litres. Ordered some from Opie, which came Wednesday then today found 5 mins and after a drive and dinner, went back out to the car (whilst still warm), expecting to glug in a third or a half litre - only to find this?????
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
Greg, ad 1/4 L oil and it will read one notch under full with engine at working temp, |
Cheers Nino, yes have done.
Greg, I check oil level in the morning when the engine is cold and all of the oil is on the bottom. like to have oil level in the middle or one notch above. |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
the 4.4 tdv8 has to have the oil at working temperature and then left for 15 minutes before you check it ...[from owners manual] ... - .- -.
I usually drive the wife to Tesco’s and check it when we finish shopping.
do you reckon an asda would be ok mike?
I like the Waitrose carpark myself!
| All times are GMT |
