Home > Technical (L322) > Which oil type 4.4 TDV8 ?
Page 2 of 3 <123>
Mine used to lose a bit, but it had a leak on a turbo and a drip from the dipstick bott connector. Now they are fixed it hasn’t used a drop in 3000 miles. There is nothing that can't be fixed with a hammer😜😜
Post #458738 27th Nov 2017 10:16pm
Vogue
Greg, I used to go between 12k and 16k between services - yes used a tiny bit of oil (as all cars do and if anyone tells you any different they are lying). But I never needed to top up, I.e. The oil used was so minimal it didn't need topping up between services. I / the main agent used the advocated Shell Helix 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #458741 27th Nov 2017 10:51pm
GGDR
Thanks again chaps.
Mine has had the oil cooler housing replaced by a main dealer before I bought the car. I think that should mean I'm ok for oil-in-the-coolant problem. Right?
Getting under the car, I've got oil under the engine, around the sump tray and bell housing area. But I think this could be due to the above, previous oil leak and not being cleaned up.
I've done the o-ring to the turbo oil pipe, although it was all very clean back there.
So I've been checking the oil monthly until I can get it up a ramp and degrease the whole bottom half.
I am doing a DPF regen every month at the moment (due to my short run driving pattern) which clears very quickly at the std 50mph. But I understand the regen can burn oil . Not too sure why. So could be that.
. Cheers, Greg
Post #458743 27th Nov 2017 11:08pm
^Check engine fault codes^ there maybe a manifold temp probe gone which over fuels the car and fills the DPF 10X quicker than normal... Thumbs Up
Post #458751 28th Nov 2017 12:15am
Baltic Blue
Greg,
Regular DPF regens will dilute the oil due to excess fuel being injected during the process.
Hence the contaminated oil should be changed more regularly, but the service indicator is suppose to be clever enough to know when an oil change is required.
I would have thought that this would show up as an increase in oil level though, not low level?
Post #458773 28th Nov 2017 9:39am
GGDR
Ok so last Saturday as you can read above I'm getting low oil, top up 0.5 litres. Ordered some from Opie, which came Wednesday then today found 5 mins and after a drive and dinner, went back out to the car (whilst still warm), expecting to glug in a third or a half litre - only to find this?????
That's a two notch variation.
All checks were on level ground too. WTH???
Greg Cheers, Greg
Post #459366 2nd Dec 2017 9:20pm
nino_nino
Greg, ad 1/4 L oil and it will read one notch under full with engine at working temp, Thumbs Up
Post #459376 2nd Dec 2017 10:50pm
GGDR
Cheers Nino, yes have done.
Thinking the name of this topic needs to change to fluctuating oil level readings though.
So weird.
So if I ignore last week's low reading, my monthly oil readings are consistent and so then I'm less worried about an il leak.
I still need to get it on a ramp and do a big clean and degrease.
Cheers guys.
Greg Cheers, Greg
Post #459410 3rd Dec 2017 9:50am
nino_nino
Greg, I check oil level in the morning when the engine is cold and all of the oil is on the bottom. like to have oil level in the middle or one notch above. Thumbs Up
Post #459433 3rd Dec 2017 2:06pm
the 4.4 tdv8 has to have the oil at working temperature and then left for 15 minutes before you check it ...[from owners manual] ... - .- -.
Post #459434 3rd Dec 2017 2:19pm
Baltic Blue
I usually drive the wife to Tesco’s and check it when we finish shopping.
Their car park is the only piece of flat land in Saddleworth ðŸ‘👠G reg 2.5VM Vogue Portofino red 1991- 1999
Post #459437 3rd Dec 2017 2:35pm
do you reckon an asda would be ok mike?
Mr. Green Wink ... - .- -.
Post #459438 3rd Dec 2017 2:40pm
Baltic Blue
Mr. Green Rolling with laughter G reg 2.5VM Vogue Portofino red 1991- 1999
Post #459439 3rd Dec 2017 2:59pm
GGDR
Smile Smile
The system won't let you check it cold, it just says 'unavailable'. At least on mine.
Both times a week ago, then yesterday it was consistently 45 mins from stopping the engine, on level ground.
Just a strange anomaly.
Yes Mike, bring back the dipstick, definitely!
. Cheers, Greg
Post #459447 3rd Dec 2017 5:13pm
GGDR
I like the Waitrose carpark myself!
Overheard in Waitrose:
"Waitrose have sold out of my favourite Duchy of Cornwall Zesty Lemon Curd so don't talk to me about your f****g problems!"
Google: Overheard in Waitrose for more, bloody hilarious Very Happy Very Happy
Greg Cheers, Greg
Post #459448 3rd Dec 2017 5:17pm
Page 2 of 3 <123>
