Home > Technical (L322) > Rear brake pipes
PicnicSteve
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Rear brake pipes
Landrover dealership just quoted me £900 for replacement rear brake pipes, (2007 vogue) sweet mother of Jesus someone please tell me I can get this cheaper else where ........ please 😂
Post #460647 12th Dec 2017 10:35pm
Dolphinboy
Depending on how far gone they are, someone on here recently had theirs coated. Could be a cheaper option?..?
Post #460656 12th Dec 2017 11:00pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Get some recommendations for locsl independent land rover specialists.
There's absolutely no way it can't be done for a small fraction of that amount when the pipe & fittings should cost less than £40!
The dealership is probably quoting for the horrendous task of trying to fit pre-shaped LR OE steel pipes - rather than making up some copper nickel pipe to fit (possibly requiring an extra joint to make it easier to feed it around the various underbody "obstacles"). Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #460657 12th Dec 2017 11:10pm
you could try doing it yourself,
http://www.fullfatrr.com/forum/topic25799.html ... - .- -.
Post #460659 12th Dec 2017 11:14pm
Pawl
Thumbs Up Paul,
Post #460660 12th Dec 2017 11:16pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
I had a similar quote from main dealer, I asked how much was the b/pipe. At the time it was about £28 the rest
I was told, "sir it is because we have to drop the rear subframe to fit the pre-formed pipe". Rubbish!!!! Censored ,
After reading Joe90s superb write up its my project for early next year.
It really annoys me that for such a iconic car that they scrimp and cut corners on stuff like brake pipes, how much would cupra nickle cost an extra £60+ on the price of a new car?.
Post #460664 12th Dec 2017 11:39pm
Sandyt
I had them done at my local garage as part of service including rear calliper carrier and tota bill was less than half that Shocked
Post #460681 13th Dec 2017 7:01am
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Having done the job a couple of times (I run a garage ) to do it properly with copper or cunifer it takes about 4 to 6 hours to do properly (lots of trim to remove) and run them right to the joints in the front wheelarch so should be about £300 to £400 at sensible labour rates , bit of a faff though .
Post #460688 13th Dec 2017 10:40am
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
I had to have the rear ones that are part flexi / part solid done for the last MOT - genuine LR ones used and it cost ~£150 including fitting if i remember correctly. 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #460731 13th Dec 2017 3:11pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I've done quite a few of these and it's not a huge job if you have the pipe flaring kit etc.
I seem to remember the only thing that really needs to come off is the plastic cover underneath the passenger seat as the pipes corrode quite badly under there. You can easily join the pipes at the front of this section as the pipes rarely corrode in front of that. In almost all cars I've seen, there are connections already fitted behind the n/s front wheel liner and it is quite easy to undo the bolts at the bottom rear of the liner and join here also.
It is a little tricky getting the pipes through the correct places across to the rear o/s wheel though not that hard. There is no need to drop the sub-frame etc. and just carefully feed the pipe through.
The job is not much more than 2 or 3-hours at the most with the car on a ramp, and the parts are probably less than £10 if you can make the pipes and joints up yourself.
£900 is obscene....! Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #460742 13th Dec 2017 5:04pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
My indie did the repair with copper in less than an hour including tea !! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #460743 13th Dec 2017 5:10pm
fisha
I'm just about to do the job on the driveway. The tool is about 30quid. The copper pipe about 30 quid , and I bought a tray of unions for 20quid.
No way would I pay £900 quid. V8 or else ...
Post #460753 13th Dec 2017 7:04pm
It is worth removing the front inner wheelarch covers on the front left (RHD passenger side) - especially the smaller one against the engine bay (this will probably break on removal Shocked ).
Lots of rusty pipework will be found ! (ref my photo tutorial!)
No point replacing the rears if the connecting pipes are shot to pieces. .
Post #460795 13th Dec 2017 10:56pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Would strongly suggest following Joe90 advice. I did mine back in February as one had split under the tank cover. The short connector pipes in the LH wheel well were nearly shot as well. 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #460797 13th Dec 2017 11:13pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Has anyone tried buying the genuine LR rear pipes and cutting and flaring the O/S pipe to make fitting across the rear subframe easier? 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #460873 14th Dec 2017 10:10pm
