![]() | Home > Technical (L322) > Help on diesel leak |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
Maybe it seals better once it warms up but just a guess |
| Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190
I thought along those lines the pressure pushes the seal tight |
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545
Have a read of This, it will tell you everything you need to know -
Cheers paul so it looks a fairly straight forward job |
| A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 159
Pay attention to this hose. Due to the heat and the time it crack and the diesel passes through it near the injection pump.
The link wont open pal? |
I never knew how to add photos here. Go to my gallery the image is there[/img] |
Yep i know the pipe you mean pal ive just done the jubilee clip on it where its goes on the pump i will check it further thanks where abouts did yours crack on the pipe itsself pump end yes |
Mine cracks near the pump. The clamp is a BMW one and is very strange to remove it. It must be done with a plier. Probably LR have a special tool for.
I know what you mean about the clip it was a fight to get that off and i did it in the dark so i didnt check the pipe but a picture of your cracked one would be a help thanks |
Any update on this one ? |
Well i havent toutched mine yet but it appears to have stopped leaking |
I think mine has done the same although i have stopped looking |
| All times are GMT |
