![]() | Home > In Car Electronics (L322) > 2010MY Amp Upgrade |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Oh wise and worldly lot...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35821 ![]() ![]() |
is it not loud enough for you Ash? ... - .- -.
Actually - No Stan
wait till you get older...AM sounds good then |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7990 ![]() ![]() ![]() |
I had the stage 2 Baris upgrade in my TD6 and it was well good.
According to the reading, there are 5 extra speakers in the 1200w system, but they been a bit cheeky, as there are 5 of the existing speakers that have a extra coaxial speaker in the same unit....centre dash....rear door lowers and the 2 at the side of the top tailgate, which only seem to work with the surround on, which is not suitable for normal music CDs..... so I recon the amp swap would give you pretty much an HD system as per the top option.... 2011 Range Rover Vogue SE 4.4 TDV8
oh no - now you've stirred it up..! |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
1200w system will have an HD symbol in the speaker grille Cheers, Greg
thx - |
As above...I thought they said Logic7HD on the speaker grilles and had a silver trim round the bottom speaker as below.......
I also believe the amp is a better quality amp, not just louder.
More info from last year.....
That makes more sense then... the ones I’d seen so far always had both together.
