![]() | Home > Maintenance & Mods (L405) > L405 Tow Hitch |
| chopdogs Member Since: 17 Feb 2011 Location: Malmesbury, Wilts Posts: 40
Sorry for resurrecting an old thread. Just had a removable tow bar and dedicated 13 pin electrics fitted by a local specialist.
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
I'm fairly sure mine beeps in reverse & I have to press the button to silence it
| b2dnd Member Since: 21 Aug 2017 Location: Carmarthen Posts: 3
Stratstone Swansea coded my L405 as a good will gesture and my car has the same problem, everything works including auxiliary caravan electrics but the parking sensors are still active. As the procedure was carried out free of charge I'm not going to make a fuss and it's probably something I'll have to live with. |
| Bessy645 Member Since: 10 Apr 2018 Location: Cheshire Posts: 11
I have the deployable towbar but it has seemingly developed a fault. The towbar deploys but not the 13 pin electric connection. I'm had to manually pull it down. When stowing the towbar it will go so far then stop. Pressing the stow button again gets it to lock away.
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Your profile doesn't say what year your L405 is Bessy.
Its a 2015 model. Not had any issues until this morning. Its a though the electrics are catching but certainly mo movement when deployed. I think they are held in place with a spring. Car is just out of warranty but I have the extended landrover warranty on it so I'm assuming its covered.
| CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779
Fitting a detachable WestFalia towbar Friday....this should be fun.....concerned it's gonna need a part or something but guy says it is complete, but I think I maybe need the undertray opening part...
| AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 419
See images of my Westfalia as fitted with swan neck part attached. I bought the rear panel with the hole but had to modify (read: butcher) it to fit.Not perfect but kooks better than a gaping hole without it and as I'm towing a fair bit in July/August I'll leave it like this. Would prefer the deployable system for looks and convenience but this is a compromise.
Smashing Andy Thanks.
You don't need to cut the panel to fit the bar you can just leave it off and then refit when you remove the swan neck part. If you aim to leave the bar on all the time then it would look tidier with the panel fitted with a cut out, you can buy a panel from LR that is already cut but it still needs some modification with an axe |
That looks quite a large cut out..... I'd have thought you could cut more tightly, but then again, it's out od sight at normal eye level.
Ah so theres a good chance I'll not have to cut anything then as it will just be beginning of boating season etc and an odd maintenace item with jetski or boat.
Quite ugly with the whole panel out - but if you rarely need to tow & it will cover all the fixed parts when it's installed, then not a bad plan.
Guys, is the swan neck exactly the same part/number as the 322 unit please? That might save a few quid if it is 👌 |
| All times are GMT |
