Home > Maintenance & Mods (L405) > L405 Tow Hitch
Page 3 of 4 <1234>
b2dnd
United Kingdom 2014 Range Rover Autobiography SDV8 Fuji White
New on here and just thought I could be of help to anyone contemplating fitting a tow bar to their L405. I just fitted a swan neck detachable Westfalia tow bar supplied by P.F.jones priced at around 370 on my L405, its the same type that was factory fitted to my previous L322. Fitting is quite straightforward once the bumper has been removed.
To remove the bumper first remove the under tray and all screws visible underneath including the two each side on the wheel arch liner. Next remove the trims either side, these just pull off from the front to reveal two more fastners, there are three plastic fastners also at the top of the bumper accessed once the tail gate has been dropped. Remember to disconnect the parking sensors plug before dropping the bumper off. Now fit the dedicated 13 pin electrics, part no VPLGT 0073 purchased from e bay for 75, this plugs into the two sockets next to the park sensor plug, remove the dummy plugs first.
All the lights work without coding however the aux for caravan does not so I have made an appointment with the main dealer to code, who knows how much lighter my wallet will be after that visit.
Finally, Westfalia give part numbers for replacement under trays, this is not necessary, you can modify your existing by cutting a hole with a Stanley knife. I've chosen to leave the swan neck attached at all times just in case some clown gets a bit close in Tescos. If any one wants pics I will add, it's dark out there now.
Post #458102 21st Nov 2017 4:39pm
chopdogs
Sorry for resurrecting an old thread. Just had a removable tow bar and dedicated 13 pin electrics fitted by a local specialist.
The trailer lights work fine but the rear parking sensors are not disabled when the electrics are hooked up (as they were on my old Disco).
Is this a dealer coding job or can it be done manually (or should the fitter have done it)?
Thanks in advance
Post #471950 10th Mar 2018 1:08pm
I'm fairly sure mine beeps in reverse & I have to press the button to silence it
Can't 100% remember & mine was factory fitted.
Post #471967 10th Mar 2018 3:02pm
b2dnd
Stratstone Swansea coded my L405 as a good will gesture and my car has the same problem, everything works including auxiliary caravan electrics but the parking sensors are still active. As the procedure was carried out free of charge I'm not going to make a fuss and it's probably something I'll have to live with. Sad
Post #472149 11th Mar 2018 4:30pm
Bessy645
I have the deployable towbar but it has seemingly developed a fault. The towbar deploys but not the 13 pin electric connection. I'm had to manually pull it down. When stowing the towbar it will go so far then stop. Pressing the stow button again gets it to lock away.
Any suggestions?
Post #480703 11th Jun 2018 5:13pm
pld118
Your profile doesn't say what year your L405 is Bessy.
Does this help?
'Deployable towbar recall
Service Action Number: Q602v2; Subject: Deployable Towbar; Publication No.: Q602v2
http://www.fullfatrr.com/forum/topic43895....bar+recall
Post #480715 11th Jun 2018 6:55pm
Bessy645
Its a 2015 model. Not had any issues until this morning. Its a though the electrics are catching but certainly mo movement when deployed. I think they are held in place with a spring. Car is just out of warranty but I have the extended landrover warranty on it so I'm assuming its covered.
The car had a full service earlier this year and has always had full LR service from new so i'm assuming it would have been checked. The towbar has become noisier I must admit. I'll call the dealer tomorrow.
Post #480718 11th Jun 2018 7:21pm
CUE99T
Scotland 2016 Range Rover Vogue SE TDV6 Santorini Black
Fitting a detachable WestFalia towbar Friday....this should be fun.....concerned it's gonna need a part or something but guy says it is complete, but I think I maybe need the undertray opening part...
@Alistair have you got a pic of your "hole" the towbar pops out of mate? all smug in my new plug!
2013 Vogue SE
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #482080 28th Jun 2018 9:35am
AndyS
See images of my Westfalia as fitted with swan neck part attached. I bought the rear panel with the hole but had to modify (read: butcher) it to fit.Not perfect but kooks better than a gaping hole without it and as I'm towing a fair bit in July/August I'll leave it like this. Would prefer the deployable system for looks and convenience but this is a compromise.
Post #482084 28th Jun 2018 10:12am
CUE99T
Smashing Andy Thanks.
I'll just get that ordered today.
I'm wondering if I can just "butcher" the current part if I'm gonna have to cut it anyway.
Thoughts? all smug in my new plug!
2013 Vogue SE
2006 Vogue
2004 Vogue
2001 Vogue
Post #482161 29th Jun 2018 7:47am
AndyS
You don't need to cut the panel to fit the bar you can just leave it off and then refit when you remove the swan neck part. If you aim to leave the bar on all the time then it would look tidier with the panel fitted with a cut out, you can buy a panel from LR that is already cut but it still needs some modification with an axe Razz
Post #482163 29th Jun 2018 7:54am
That looks quite a large cut out..... I'd have thought you could cut more tightly, but then again, it's out od sight at normal eye level.
The deployable one is just one side to allow it to fold back out of the way -
Post #482171 29th Jun 2018 9:32am
CUE99T
Ah so theres a good chance I'll not have to cut anything then as it will just be beginning of boating season etc and an odd maintenace item with jetski or boat.
Handed it to garages morning and they were not sure about fitting it, so not doubt I'll end up fitting it myself, but thats fine.
Brakes are mandatory so as long as they do them thats ok.
Thanks for the pictures and explanations chaps. all smug in my new plug!
2013 Vogue SE
2006 Vogue
2004 Vogue
2001 Vogue
Post #482176 29th Jun 2018 10:30am
Quite ugly with the whole panel out - but if you rarely need to tow & it will cover all the fixed parts when it's installed, then not a bad plan.
I saw this one time in a car park -
The covers come up on every so often - there's one on eBay now for a deployable - so if your electrics will go that side, might be a good plan Thumbs Up
Post #482178 29th Jun 2018 10:43am
England 2007 Range Rover Autobiography TDV8 Java Black
Guys, is the swan neck exactly the same part/number as the 322 unit please? That might save a few quid if it is 👌 Thumbs Up
Post #482180 29th Jun 2018 11:10am
Page 3 of 4 <1234>
Site Copyright © 2006-2019 Futuranet Ltd & Martin Lewis
