![]() | Home > Maintenance & Mods (L322) > Brakes, to grease or not to grease, that is the quesation |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 ![]() ![]() ![]() |
I am fitting new rear pads and disks.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35702 ![]() ![]() |
this is what it says in the WM so i would say yes..
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 708 ![]() ![]() ![]() |
Mating surfaces means where the pads slide in the caliper NOT between the pad & piston(s) .
ah, that makes sense |
Don't add grease to the back of the pads - it does nothing positive !
It's worth adding that NO vehicle OR brake manufacturer uses grease between the pads & pistons to stop squeal.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1469 ![]() ![]() |
I've just replaced all my brakes and the WM gives very specific instructions about applying grease to the areas on the back of the pads that are in contact with the pistons. 2021 D350 Fifty Edition - Carpathian Grey
Thanks for all the reply’s, if only I had the relevant page of the workshop manual. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3833 ![]() ![]() ![]() |
Q.E.D.
I'm very surprised if the Land Rover manual suggests using grease between pads & pistons.
So where do you put the grease then? |
The page that Baltic Blue posted is from the 2010-2012 WM 2021 D350 Fifty Edition - Carpathian Grey
I'm busy looking for a hat to eat - lol. |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
The new genuine pads I've just put on the front (6 pot brembo calipers) had a sticky adhesive layer on the back of each pad too. 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
